Picture request: engine short block top view
Any one have a good top view (looking down) of a short block?
I'm looking for a clean, clear picture of an engine with no accessories or intake installed, centered above the engine, no angle, straight down. I am trying to find this so I can print it to scale and use it as a template for an ITB project. Unfortunately, I don't have a spare engine for mock up.
Similar to this, but from the top side
Thanks in advance
Old 03-10-2017, 01:10 PM
Jameel's Avatar
That's a tall order considering the issues with parallax and lens distortion. I can shoot mine in a couple days, it's a 3.0 stock. But don't you mean long block? Short block is just the case, right?
Old 03-10-2017, 01:19 PM
dlagerstrom's Avatar
How is this?
I can send you the full size if you like.
Cheers.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 03-10-2017, 03:12 PM
Stranger on the Internet
patkeefe's Avatar
I suspect you would have to be the best machinist ever to build ITB's from a photo. I doubt even NASA could dimension that.
Patrick E. Keefe
78 SC
Old 03-11-2017, 08:24 AM
Cad File
Save yourself considerable amount of time. Flat Six Cad File
I have used it for rough environment file, I have not check how accurate it is.
I think he offers the file up on different site, I paid less than half price.
Outlaw .... by definition ..... does not follow rules well
www.FloydDesign.ca
https://www.youtube.com/watch?v=sV5aIALWlG8
Old 03-11-2017, 09:01 AM
faverymi's Avatar
Get some cheap used carb manifolds.
Old 03-11-2017, 09:13 AM
The Jenvey site gives the dimensions of the manifolds. I know the ports are 118mm center to center but not sure of the distance and offset from one side of the engine to the other.
Old 03-11-2017, 12:22 PM
Under the radar
Trackrash's Avatar
Nice CAD work. Too bad the fan is backwards.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-11-2017, 03:25 PM
Thank you to those who tried to help.
This is exactly what I was looking for. The CAD file is amazing.
To clarify, I have a working Triumph ITB setup on my car that I am working on a push/pull linkage setup vs the weber crossbar setup. I want to get the linkage 95% before tearing my car apart again. Again, I was looking for a photo for a template.
Current setup
Old 03-12-2017, 02:31 PM
Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Take a look at my linkage. Also triumph based, but with the bodies spaced out to 118mm
Old 03-13-2017, 03:57 AM
Banned
Maybe this helps. It's a DXF file of both flanges (911 and triumph) correctly aligned.
https://drive.google.com/file/d/0B2uyAaRLzIxGblh5NmQ4ZU1TYXc/view?usp=sharing
Old 03-13-2017, 04:09 AM
Good stuff.
A few years ago I modeled a manifold to adapt the triumph ITBs to the 911
And since then i've had them casted
So i'm all set on the manifolds.
I'm playing with a few different linkage options and aluminum fuel rails to replace the stock plastic ones now, since I can't leave well enough alone.
Old 03-13-2017, 05:25 AM
Banned
As i used the 911 bore spacing (118mm) i was able to use cheap, used fuel rails from a boxster
Old 03-13-2017, 06:36 AM
