Is the light switch illuminated?
On 3.2 Carreras Probably SC too, the Fog Lights switch is illuminated when the fogs are turned on. Does the main light switch also illuminates? If it does how does one replace a burned bulb in these switches?
Old 03-23-2017, 11:25 PM
Member 911 Anonymous
DRACO A5OG's Avatar
No it is not on pre '87s, what year is your car?
'85 Carrera Targa
PCA/POC
Old 03-23-2017, 11:55 PM
I'd also like to know how to replace the tiny bulb of my fog light switch. Seems so tight in there. 1988 carrera
Old 03-24-2017, 12:41 AM
DRACO A5OG's Avatar
Fog light is easy
Just peal off the rubber or gently remove plate and bulb will be exposed
Use forcips to grab bulb gently and pull it out
Old 03-24-2017, 08:15 AM
'86. Thanks for confirming that the light switch is not illuminated.
Old 03-24-2017, 09:54 AM
Fog light is easy
Thanks!
