Is the light switch illuminated?
On 3.2 Carreras Probably SC too, the Fog Lights switch is illuminated when the fogs are turned on. Does the main light switch also illuminates? If it does how does one replace a burned bulb in these switches?
Member 911 Anonymous
No it is not on pre '87s, what year is your car?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I'd also like to know how to replace the tiny bulb of my fog light switch. Seems so tight in there. 1988 carrera
Fog light is easy
Just peal off the rubber or gently remove plate and bulb will be exposed Use forcips to grab bulb gently and pull it out |
Thanks!
