82 911SC Guage lights not working but they function properly
So just got my car back and the lights are not illuminating on the gauges. The headlights work both high and low. The turn signal indicators work as do the blue light in the center of the gauge for high beams. Also the check battery light or alt light works. So its seems its just the lights on the sides that illuminate the #s and info. We added Xenon HID lamps. I also switched out the tach and clock to OEM (car had a turbo tach on a non turbo car and the clock was a custom fuel/air gauge).
Fuses are good gauges all work properly. I'm thinking headlight switch dimmer went bad? Also the bright light/turn signal switch was stuck on H-Beam but I got it to click back today to normal low beam setting. It also had the J west relay already in the car when I bought the car. All gauge lights worked and had been converted to LED.They were nice and bright. I know that's allot of potentials but I just find it strange that just the instrument dials wont light on all of the dials, not just a specific one. Any help would be great.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 03-30-2017 at 11:46 AM.. |
ROW '78 911 Targa
Were the gauge lamps fused at some time? Could be a blown fuse.
You can move the inst lights off the dimmer circuit at the light switch, if the dimmer is shot. Search for the labeled light switch photo in the forum. Could also be as simple as the blue/black wire lighting harness came unplugged where it connects to the main dash harness behind the gauges. (They all come together to one common single wire connector)
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 03-30-2017 at 12:10 PM.. |
When you turn your lights on do your heating and ventilation panels still light up?
Matt. 83 911SC 85.5 944 NA - Sold |
There is the knob that does the bright and dim on the gauge lights. Has this gone whacky.
Its a stripped out car, the E brake light comes on the dash
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) |
How about fog light switch, defroster switch, or hazards switch? Do you still have any of those? Sent from my iPad using Tapatalk
they do light up
Ok. So I think that rules out the light switch. Those items are powered from the same 58a pin. I think timmy2 may be right. All the lights come to a connection in the dash before they go to the light switch. Maybe it disconnected. Pull out the gauges you say you replaced and see if all the connections are made to the back of the gauge. Then see if you can find that group connection to see if it's connected.
ok thanks
