Checking idle control valve (ICV)
Good morning - hope everyone had a good weekend.
I am trying to sort of an idle issue with my '74 with a 3.2 and I just pulled the ICV. I cleaned it with carb cleaner and when i shake it I can hear the piston moving. I have 40 ohm resistance between the outer pins, and 20 between inner and outer.
That suggests that the ICV should be in working order, correct?
Thanks!
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 04-03-2017, 06:33 AM
That Guy
Techno Duck's Avatar
You can use a 9v battery and put power on the ISV; this will cycle the valve open and closed.
Bench testing Carrera Idle Control Valve
When you put the ISV back on, you can reset your base idle by bypassing the ISV and adjusting the air bypass screw on the throttle body. This will give you a good baseline to start from.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 04-03-2017, 07:25 AM
Thanks Jon
911 w/ 3.2
Old 04-03-2017, 07:45 AM
steely's Avatar
When plugged back in, and with the key ON (eng off), you'll feel it vibrate and might hear the buzz. This tells you the DME is powering/ driving it.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 04-03-2017, 10:38 AM
Just check and the unit is vibrating. I think I have a microswitch issue.
Thanks!
911 w/ 3.2
Old 04-03-2017, 11:25 AM
wrxnofx's Avatar
My '87 started surging pretty badly. I removed the ICV, cleaned it, and verified it worked using a 9 volt battery. However, the engine still surged. I ultimately bought a used ICV and swapped it out. Haven't had a surging problem since.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 04-04-2017, 09:05 AM
Mine had the same problem. Found out someone installed the ICV backwards with the arrow pointing up.
Old 04-09-2017, 04:36 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
It's a consumable, got one online problem solved for another 30 years....
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-09-2017, 07:09 PM
Member 911 Anonymous
DRACO A5OG's Avatar
OP, so what was the issue to suspect the ICV?
'85 Carrera Targa
PCA/POC
Old 04-10-2017, 12:37 AM
