moparrob's Avatar
Need help finding body plug part number
I just stripped out my rear seat area and want to replace the two rubber plugs under the rear seats but I cannot seem to locate the plugs or the part numbers for them. These are the plugs (not my car though)
Does anyone know where to get these or the part number or size?
Much appreciated.
Old 04-23-2017, 08:54 PM
Brew Master
cabmandone's Avatar
I think I have 1 or two of those plugs in my shop. Measure the hole and let me know what size it is. If I have them, they're yours.
Old 04-24-2017, 06:45 PM
moparrob's Avatar
Thanks, that is very nice of you. The car is at another location so I will stop by tomorrow and measure them. I never knew they would be so hard to locate.
Old 04-24-2017, 07:11 PM
Bill Douglas's Avatar
Wow, the strippering/cleanup went well.
Old 04-24-2017, 10:03 PM
moparrob's Avatar
That picture is not of my car. This is the thread to my endeavors from last weekend:
My experience with citrus stripper, what now?
Old 04-24-2017, 10:42 PM
Administrator
Luccia at Pelican Parts's Avatar
If you don't have any luck give us a shout and ask for Bruce. He might be able to help you. 1.888.280.7799. Good luck!
Old 04-25-2017, 08:42 AM
hotdogwater's Avatar
I stripped my interior and had to replace all of the plug inserts. On my car 1970T these were metal discs that are glued in with seam sealer. What year is your car?
Couldn't find part number (not even shown on parts diagrams I don't believe) and posted here but go no response. I did have a shop cut me some and I should have some left over if you can't find any or find you need a lot of them ( think it took 12 or 13 to do my entire floor pan and rear seats) let me know. Most all of my plugs had rusted so I replaced them all when restoring the interior just sealing them in with new seam sealer.
Here is the post I made about the strip down in case you are going that far. Floorboards and interior stripping (2015 edition)
-70' 911T -in resto - (runs after 25+ years)
-74' 914/4 - race car - SOLD -
Old 04-25-2017, 09:27 AM
moparrob's Avatar
Well now I am a bit embarrassed. It ends up those are not body plugs. There are depressions in the metal Seat pans that were filled with some sort of black tarry substance that I thought were plugs. Thanks anyhow.
Old 04-27-2017, 01:42 PM
Are you sure there isn't a flat metal disk sealed inside that black tar? Not sure you read all the replies above or maybe your car is different but most of these are filled in with seam sealer (the black tar stuff you mentioned) and a metal disc/plug. Maybe not fair to call it a plug but all of the drain holes in my 70 911 had discs sealed in them. The only real rust I found in my floor pan was in these plugs. If the sealer is hard and brittle its' probably time to remove and replace the sealer and the disc/plug if their is rust starting.
Old 05-01-2017, 09:41 PM
moparrob's Avatar
Well I'm not 100% sure but it sure seemed like it. I will need to wheel the car into the the sunlight next weekend and take a heat gun to those areas to see what lies under the goop. Thanks for the input.
Old 05-01-2017, 10:22 PM
