LinkBack | Thread Tools | Rate Thread |
Oil all over engine and pouring out when engine heated up and running.
I just got my 911 sc out of service having the fluids changed. Nothing too involved but the mechanic did clean up the engine and tighten the valve covers as well. Just FYI, the car has Weber carbs. When I got the car back it started and ran fine. About 10 miles down the road as the engine heated up the car began to smoke like crazy from underneath so I pulled over and cut the engine. Oil was pouring onto and past the headers and smoking. When I opened the engine bay it and the engine were covered in oil. I assume wherever the leak is-oil was not just dripping downward---oil had sprayed everywhere like on the carbs, plug wires etc. The car has been towed back to the mechanic but I wanted to see if anyone had any ideas.
Guess he overfilled it, eh? 10 qt w/filter is safe. Did he drain both the tank and the engine case before adding oil?
Still here
101 Projects for Your Porsche 911 - PelicanParts.com |
That's what I was thinking.Oil indicator was at the top. Is it possible to hurt the engine?
Where would the most likely leak location when overfilled be?
Out the breather hose that connects just in front of the oil fill cap. No harm done, other than the mess. Does this guy work on 911s much?
mikl911
Usually from the fill tube vent on the oil tank fill tube. If you look where you put the oil in there are usually a couple of lines that run into the side of it, one to the case breather the other to vent the pressure and or access oil. Been there done that. It can happen if your 1. mechanic checked the oil level while it was cold and filled to the full line once warmed up properly the oil expands, or 2. forgot to drain the oil tank and just added 10 quarts with out checking it.
Mikl911 1967 911 RS clone owned since 1992 1978 911 SC/R Sinister hot rod 1937 Ford Slant back Hot Rod 2000 M5 ECU upgraded (sold) |
jiffy lube.
#JiffyLube...........
Does the "mechanic" know that the oil level is checked on a hot engine while idling?
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
Sometimes the oil filter is loose, or the old gasket is stuck to the car. Twin gaskets can work for a while, and then blow out.
And you get to rebuild those carbs again because guess where some of that oil has ended up? I once found the air filter housing full of oil to the brim ...
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
88 Carrera, Guards Red
who changed the oil
