Weber conversion Carrera 3.0
Hello
I would like to switch to a CIS system with the WEBER 40 IDA 3C.
What can I put on as an intake manifolds. The engine is a carrera 3.0
Does PMO manufactures an intake manifolds?
thank you in advance
Old 05-20-2017, 09:52 AM
RETIRED
Joe Bob's Avatar
Most used Webers are used up. PMO makes a great product and will supply everything you need with a better carb than the original. Pricey but worth it.
If I remember he only deals with the initial order via fax. After you buy he does talk on the phone or via email.
Good luck.....BTW, switching to carbs is best if you upgrade the cams and tweak the ignition. Stock FI cams on the 3.0 aren't the best with carbs for performance and/or mileage per gallon.
2012 ML350 3.0 Turbo Diesel
Old 05-20-2017, 10:23 AM
wayner's Avatar
Yes
Even with webers use the pmo intakes
They are engineered to block off the cis ports
SOLD - 914 wide body hot rod
Old 05-20-2017, 11:31 AM
Thank you for your reply
I know that PMO carburetors are very good but I already have the weber in very good condition.
Old 05-20-2017, 11:39 AM
wayner's Avatar
Also, when you order your PMO manifolds for your weber carbs also order the spacers(or insulators) or whatever he calls them
Note that the factory manifolds won't work
Old 05-20-2017, 02:29 PM
Do you have to run insulators? My mechanic put the tall PMO manifolds on my 2.7 spec. Motor but did not install insulators.
Old 05-20-2017, 02:48 PM
I have this set up on my 3.0 big port motor. I used the 46MM PMO tall intakes with weber 40's and it works great. Excellent low end throttle response. I also have Web Cams with SSI's and it feels stronger than my 3.2 motronic motor.
Best of luck
Bob
Banda
69 911T 3.4 ltr. Outlaw build
72 BMW 2002ti Alpina "Pig Cheek" build
Old 05-20-2017, 02:49 PM
No you don't have to run the insulators but they are a good idea as they are a heat barrier.
Old 05-20-2017, 02:51 PM
I would have to put new studs. I don't think mine are long enough for insulators.
Old 05-20-2017, 03:20 PM
I heard fuel boiling in my webers before I put insulators in.
Longer studs came with the kit, if I remember correctly.
72 911 coupe 2.7L S Cams/Webers Street/Track
68 912 coupe 1.6L sold
Old 05-20-2017, 03:47 PM
Vintage Owner
Jack Stands's Avatar
On my 2.7, I used the PMO kit and did use the insulators. Then I installed a switch that allows me to turn off the fuel pump before parking the car. That allows the fuel in the float bowls to drop to a lower level and helps with the hot fuel percolating. Especially with today's ethanol laced fuels, it helps cut down on the fuel boiling out of the vent tubes.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 05-21-2017, 06:38 AM
disband
juanbenae's Avatar
Best of luck
Bob
what webcam grind did you use? I have used the 120/104 grind and have a had terrible time getting off a rich at idle and highway cruzing speeds AF.
Old 05-21-2017, 09:58 AM
Thanks for all your answers
Someone has already ordered from PMO, could you please explain how did you proceed ?
Thank you
Old 05-28-2017, 01:47 PM
Bill Douglas's Avatar
It seems a shame to mess with such a beautiful engine as a Carrera 3.0.
Old 05-28-2017, 02:09 PM
ROW '78 911 Targa
timmy2's Avatar
From what I've read, PMO only accepts orders and questions via fax machine.
Fill out the ordering information and ask any questions. He will get back to you.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-28-2017, 02:42 PM
I known kjet injection isn't the best one but it s possible to change when ever i want to the original configuration. I just want to try it
Old 05-29-2017, 02:27 PM
There's only one problem for me.... to found a fax
It's a joke.... i suppose I can send faxes with internet...
Old 05-29-2017, 02:30 PM
ROW '78 911 Targa
timmy2's Avatar
Old school, but keeps one from answering emails all day long...
Lots of free apps out there that will send a fax from your smart phone.
Dennis
Old 05-29-2017, 03:00 PM
pics please when done
Old 05-29-2017, 03:01 PM
CBRacerX's Avatar
You want to end up with something like this. XDi ignition not required
Sent from my iPad using Tapatalk Pro
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 05-30-2017, 04:58 AM
