Good luck, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
I need some help. My passenger door will not close without slamming the door an few times. However it closes perfectly the first time if the drivers door is open or the passenger window is open.
I want to install a time delay relay using the door light switch as a trigger. When the door is open the trigger will lower the window for a few seconds (x) and when closing the door the window will close the window for x seconds. Which wire/s on the switch controls the up and down function movement ? Last edited by Reuben911; 11-24-2019 at 07:15 PM.. |
Hi Reuben. red/black and red/white. You'll need your mulitmeter to figure out which is the up and which is the down. The black and the green go to the winder motor and brown is ground (earth). Sounds like a good idea, Bill.
Thanks, will post results when done
I had similar problem...fought it forever. Finally determined the wire going through the door to the switch had a kink in it and would randomly make/lose connection. Drove me nuts thinking I'd fixed it.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
gruppe f
I have a passenger window problem that differs from the OP's. In my '87 Carrera, both driver door switches work, but the passenger door switch does not. I have tried swapping the switches, but the problem persists. Any ideas? TIA.
Mike Hinton '06 Cayman S Carmon Red, '05 Cayenne Turbo Black, '87 Carrera Granite Green, '72 911T Aubergine, '74 914 1.8 Marathon Blue, '64 356C Aubergine |
Passenger side?
Well, some time ago mine quit working because...
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
gruppe f
I'm sure that I don't have the same problem. I can lower and raise the passenger window with the switch on the driver's door, but the switch on the passenger door will not raise or lower the window. Swapping the working driver door switch to the passenger door did not fix the problem.
Fixed my pass side today. Window would not raise. Hit the door panel by the switch and it started going up and back down then quit again. Removed the door panel, window switch, checked the wiring, cleaned all contacts, sprayed contact cleaner into the window switch. Works like a charm now.
'84 Carrera Cabriolet |
FLOJO!
How many times was that motor drove into the hard stop up or down side to create the cracks on that motor!? Wow. When I started fussing with my motors in the doors I was expecting to see such a mess, but those motors are quite over-engineered with AlCuZn (or some zinc alloy) for the gear box: you may want to send that to the PE at Porsche to see how he reacts.
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
Hi everyone, new here and new to Porsche. I have a 1980 911 SC. My windows on the driver side works but the passenger side doesn’t. I already tested the motor and fixed the regulator but still not working. Thanks.
Howdy, I have an 85 911 coupe. I am experiencing a weird problem (at least to me) with my power windows.
This is the issue. I replaced the passenger side window switch, followed the pics in this topic and in Bentleys manual. When I rewired the switch down was up and up was down. Also, the drivers side window switch works as it should, the drivers side passenger switch does not work at all now. I replaced the Drivers side pass switch with a new URO switch. Still does not work. So I went back to the passengers side switch and verified that the wires are in the proper locations and they are. interesting note, in the Bentleys manual the 1984 911 wiring for the drivers Side pass switch wire colors match those in my car. For the passengers side switch, the 1986 wiring colors match. Both the drivers window switch and the passengers switch move the window up and down. The drivers side pass switch does not work. So, I am bit at ends here. Any suggestions? Chasman |
Clean the female side of the terminals, triple check the wire placement. Use a multimeter, are you actuating a pulse? Is your ground bad? . Fox and hound or short test the wires. That’s all I have
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Switch
If up is down, and down is up, your switch is upside down.
Or, the two directional wires are transposed. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 03-24-2023 at 07:20 AM.. |
