Anyone running Wilwood or AP Racing calipers
I have a 1980 911sc and I'm curious to see what caliper options people are running. My calipers need a rebuild but i also like the idea of having brand new Wilwood 4 pots.
I have seen it done, looking for info to do the same. Such as model number of calipers, if a need an adapter, rotors, pads, lines etc.
Any info would be greatly appreciated, new to the Porsche scene and trying to learn all i can.
Thanks Pelicans!
-TJ
Old 01-04-2017, 01:14 PM
gumba's Avatar
I run these on my vw bus with 911 slotted/vented rotors with 8x16 3 pc. Fuchs.
Wilwood High Performance Disc Brakes - Caliper Product Number: 120-11137
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 01-04-2017, 04:42 PM
Elombard's Avatar
Harold are those Turbo rotors?
Also are you using an adapter or is that a "bolt on". Do you have to machine the rotors?
Those almost look like they would fit under 15" fuchs
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 01-04-2017, 06:00 PM
gumba's Avatar
911, not turbo rotors. No adapter, no machining. The 3.5" spacing is the same as a 911. Looks like about 1.5" from the outside of the rotor to the inside of the wheel. Not sure if you would need a spacer to center the caliper over the rotor. The caliper model is based on the rotor width and diameter range. It looks like they would clear a 15" wheel, but you may need a spacer to move the wheel out like the 930 calipers with 15's.
You would need to look at the Wilwood site to see which caliper works with the 930 rotor if that's what you wanted to use.
Harold
Old 01-04-2017, 08:26 PM
El Duderino
tirwin's Avatar
I looked at Wilwood's site recently and just checked again to make sure I wasn't crazy. They show no brake kits available for any 911 that I could find. I tried 83, 84 & 89 model years with SC, Carrera and 930 variations. Am I missing something?
EDIT: Is that their Forged Superlite caliper?
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 01-05-2017, 03:14 AM
Bill Verburg's Avatar
Running a racing caliper which doesn't have dust seals on the street isn't a great idea.
When run on a track car they are rebuilt and attended to frequently.
Bill Verburg
Old 01-05-2017, 04:03 AM
gumba's Avatar
Yes, it's their forged superlite. There is no kit. Caliper choice is based on rotor diameter and thickness. The caliper I used works with the 911 rotor.
Harold
Old 01-05-2017, 05:35 AM
Elombard's Avatar
Thats not a 911 spindle I guess?
Old 01-05-2017, 06:54 AM
911, 914-6, 928
My '72 has Wilwood calipers on the front (bought it that way). Don't know what model or what rotors are being used. I can take photos if needed.
Old 01-05-2017, 06:57 AM
gumba's Avatar
A bus disk brake spindle with a 912 hub. Not sure why that matters. I use to run a smaller Wilwood caliper that worked with the 912 solid rotor. On the back, I run a Wilwood caliper with a turned down Boxster rotor.
I know there are other guys running the Wilwood calipers on their 911's, maybe they will post some photos.
Harold
Old 01-05-2017, 07:12 AM
I would ideally like to run the wilwood calipers with the stock size 911 sc calipers. Anyone running this setup? Also what measurements would I need to take into consideration to order the right caliper? I know the mount will need to be 3.5in but other dimensions I'm unsure off.
Old 01-05-2017, 09:05 AM
Photos would be greatly appreciated. Might have a series number on the rotor to refenrece what rotors are used
Old 01-05-2017, 09:11 AM
Elombard's Avatar
TJ
Why? The main reason to change brakes is for increased thermal capacity. If you are running the same discs its purely cosmetic.
At a minimum you can upgrade to the 84-89 Carrera discs with the Willwood - a little thicker but I am not sure I would bother.
I am pretty sure there is one style of caliper that is available with 3.5" bolt spacing, the only difference after that is rotor width accommodation. To run the Carrera discs you would want the same caliper that Harold used. otherwise look up the spec for the thickness of the SC disk and see if they have a caliper with that range.
One other issue will be brake balance, when you change the piston sizes the proportion of pressure front to rear changes and it will be un safe and uncomfortable if not near stock. This has to be accounted for with a proportioning valve added to the system or a change in master cylinder. This can probably all be worked out with some work....but its a lot of work with no thermal advantage? So in my mind it only becomes worth it if you can run larger turbo size rotors...which is also not straight forward, i.e. two piece rotors and custom hats.
Old 01-05-2017, 09:40 AM
Also consider your replacement rotor options when doing a brake system upgrade.
The further you stray from center,the more you are locked into a specific caliper mfgrs' replacement rotors. Some brake caliper have limited "off the shelf "rotor options.for instance if you want to move from a x drilled to a gas vented rotor ,it may not be available .
1979 SC
1986 Carrera 3.6 L+
Old 01-05-2017, 09:50 AM
porsher
aston@ultrasw.c's Avatar
As an alternative how about 996 brakes? Rebel racing makes a very nice kit.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 01-05-2017, 10:03 AM
Originally Posted by Elombard View Post
TJ
not worried about thermal capacity one bit, mainly doing it for ease of swapping for brand new calipers as mine are used and have been sitting for some time. Have always loved wilwoods and wanna just have something a bit different than stock.
Calipers need replaced anyways and wilwood makes great stuff at affordable prices so to me is right up my alley.
Car won't see the track or anything crazy, just fun weekend cruising around town
Old 01-05-2017, 02:46 PM
I have looked into this but if there is a compatible wilwood id opt for it. Cost is cheaper per caliper plus no need for an adapter to run them.
Just my opinion of course
Old 01-05-2017, 02:47 PM
There is a Wilwood superlite caliper that can work over a Carrera front rotor. It may be an option if you don't need a bigger rotor and thermal capacity. Just pay attention to F/R balance. See this post:
SC Brake Upgrade ??
Rick
1978 911SC
Old 01-05-2017, 03:47 PM
gumba's Avatar
You can always swap out the stock rear caliper with a corresponding Wilwood to match the front. With my first Wilwood up grade I talked to tech support about the appropriate rear caliper.
Harold
Old 01-05-2017, 07:05 PM
Ryan H's Avatar
Hey Fellas,
I called a good friend at Wilwood today and told him us air cooled guys are ready for a kit and it must fit under 15's. It's now being discussed. I'll keep you guys updated!
I've used Wilwood on all my vehicles since the late 90's.
2007 GT3
1982 911SC
1998 Integra Type R
Old 01-05-2017, 08:25 PM
