1982sc cam timing values in waynes book
Why does the 1982 sc have two different cam timing values depending on the engine #?
1978-1983sc 930/04-/10 is 0.9-1.1 1978-1983sc 930/03-/17 is 1.4-1.7 If one of these values were set incorrectly (in other words reversed) how much would that effect performance? Thanks Last edited by gomezoneill; 07-25-2017 at 08:12 AM.. |
Hi there..the bottom number 930/60.... are for Turbo..it could be a misprint in that Wayne book -i have never seen it ...For your engine you should go by 930/16 so the 1,4-1,7
Ivan Last edited by proporsche; 07-25-2017 at 08:06 AM.. |
i did have a look and you said or actually have written this ..1978-1983sc 930/60-/66 is 1.4-1.7..right those are numbers for 911sc 1982-3 compare to earlier model of 911sc..
Ivan |
no problem..but you did do the cam timing as for the 1,4-1,7 on your 911 ..right?
Ivan |
Yes 1.4-1.7
