Will EFI from 3.2 retrofit to 2.4 and 2.7 engines ?
I am hating my CIS and it's either carbs or EFI. The newer EFI seems to work well, or am I just dreaming ? Wanting to run better cams, higher compression and EFI if possible. Last edited by Mukilteo911; 02-04-2003 at 11:19 AM.. |
Irrationally exuberant
Have you priced Motec? I think it runs about the same as a 3.6 conversion especially once you add all the dyno time.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Are you thinking Motronic?
Doug 75 911S |
Senior Member
Motec will work on any type of four stroke combusion engine. It's probably overkill for your purposes.
Dam I meant motronic, or whatever is setting on top of a standard 3.2 liter
Edit your message and change the title. :-)
Warren & Ron, may you rest in Peace. |
Motronic might work (I dunno - difference in capacities, need to add various sensors), but it is much less likely with different cams.
The cams in the 3.2 are pretty mild. Less than E cams and more like T cams. Motronic's airflow sensor can't deal with cam overlap, as I understand it. Lotsa people have good CIS and are pretty knowledgeable on the whole system - what are you have problems with? MoTeC on the other hand will work. But it is ex$pensive....... very.
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
Well it is real jerky around 2 to 2.5k (where it runs mostly in heavy seattle traffic) and is very unresponsive under 2k rpm. I find it much more difficult to drive than my 70 with carbs.
It seems like there are two modes full throttle and off throttle. It would be worth money to me to make it easier to drive as I plan on keeping it until I die of old age. |
You could fix your CIS or you could go with SDS or some other FI. I priced SDS one time and I think it can be done for around $3k. Not cheap but I bet it is better than the sucky CIS.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Go for MFI.
'69 911E 2.7MFI ;996TT;987.2 CaymanS '71 Volvo P1800E wife's; AMG SLK wife's '71 Volvo race car 944S; 986S ; 734WHP drift car (son's) |
