Will EFI from 3.2 retrofit to 2.4 and 2.7 engines ?
I am hating my CIS and it's either carbs or EFI. The newer EFI seems to work well, or am I just dreaming ? Wanting to run better cams, higher compression and EFI if possible.
Old 02-03-2003, 05:20 PM
Irrationally exuberant
ChrisBennet's Avatar
Have you priced Motec? I think it runs about the same as a 3.6 conversion especially once you add all the dyno time.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-03-2003, 07:21 PM
dougcl's Avatar
Are you thinking Motronic?
Doug
75 911S
Old 02-03-2003, 08:06 PM
Senior Member
john_colasante's Avatar
Motec will work on any type of four stroke combusion engine. It's probably overkill for your purposes.
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 02-03-2003, 08:39 PM
Dam I meant motronic, or whatever is setting on top of a standard 3.2 liter
Old 02-04-2003, 09:42 AM
Edit your message and change the title. :-)
Warren & Ron, may you rest in Peace.
Old 02-04-2003, 09:49 AM
CamB's Avatar
Motronic might work (I dunno - difference in capacities, need to add various sensors), but it is much less likely with different cams.
The cams in the 3.2 are pretty mild. Less than E cams and more like T cams. Motronic's airflow sensor can't deal with cam overlap, as I understand it.
Lotsa people have good CIS and are pretty knowledgeable on the whole system - what are you have problems with?
MoTeC on the other hand will work. But it is ex$pensive....... very.
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 02-04-2003, 01:28 PM
Well it is real jerky around 2 to 2.5k (where it runs mostly in heavy seattle traffic) and is very unresponsive under 2k rpm. I find it much more difficult to drive than my 70 with carbs.
It seems like there are two modes full throttle and off throttle.
It would be worth money to me to make it easier to drive as I plan on keeping it until I die of old age.
Old 02-04-2003, 01:36 PM
You could fix your CIS or you could go with SDS or some other FI. I priced SDS one time and I think it can be done for around $3k. Not cheap but I bet it is better than the sucky CIS.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 02-04-2003, 02:25 PM
Go for MFI.
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 02-04-2003, 02:53 PM
