Exclamation Source for a ZF LSD (915)?
Anyone know a current source for a ZF LSD to fit a 915 gearbox (1973)? Any condition. Thanks.
I think the P/N is 901.332.053.13 but not positive.
Old 10-11-2017, 04:34 PM
The problem isn't acquiring the LSD, the real issue is getting the special LSD flanges needed for those coarse-spline units. Just unobtanium now.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-11-2017, 05:28 PM
Ahh, wasn't aware of that. So perhaps I should just put in an OSG unit? No axle/spline changes required? Only for normal road use.
Old 10-12-2017, 09:46 AM
Elombard's Avatar
The OSGs are $$$$ aren't they? Have you looked at the Guard options?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 10-12-2017, 09:55 AM
I found this recent thread to be both topical and illustrative Should I put Guard LSD in a 2.2??
Old 10-12-2017, 10:06 AM
Geary's Avatar
If you MUST have a ZF, I've probably got the last new ZF 915 housing in existence. I'd have to build it with Guard internals, but that would allow you to use your standard flanges. Not cheap. PM me.
Old 10-12-2017, 06:05 PM
Geary's Avatar
OSGs are cheaper, but you pretty much get what you pay for ..
Old 10-13-2017, 07:43 AM
gearhead
If you think a Giken is $$$$, a GT must be $$$$$$
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 10-13-2017, 09:32 AM
This seems like a no-go scenario. I don't want to change the gearbox or do anything custom...just add the factory LSD option.
Wish it was like sticking a locking diff in the old landrover. Turn a few bolts and presto.
Old 10-18-2017, 02:43 PM
Turbonut
Raceboy's Avatar
I have coarse splined ZF LSD in my 915 that is undergoing a complete rebuild at the moment, could replicate the flanges if they are in such a high demand?
I can make a drawing at least, just a bit of Solidworks.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 10-18-2017, 10:46 PM
Sadly, they are not high demand, however its a critical item for anyone needing coarse-splined LSD flanges as they are long NLA.
The key will be making good, relaible parts.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-18-2017, 11:31 PM
Turbonut
Raceboy's Avatar
I will make the drawing before gearbox gets assembled just in case I may need it some time.
We have made quite a few parts just by making a good drawing and then just have them CNC milled from preferred metal.
Old 10-18-2017, 11:45 PM
Hej Væger
I have ZF LSD vit flanger For sale
Vh Ole Olesen
Denmark
pone 004522834567
Old 10-19-2017, 04:38 AM
Just off of the top of my head, I expect the flanges are from forgings and the splines are broached.
I wouldn't consider barstock / "billet" equivalent to a forging for a part like this even if you find the same alloy.
It's not the kind of part you can get from just any machine shop, especially in small quantities.
1981 911 SC
2013 Mini Cooper JCW
2017 GMC K1500
Old 10-19-2017, 05:22 AM
gearhead
For quite a while now a used early 915/914 lsd has been around $1500-2000. The flanges are generally $400-500 each. So $2300-3000. A Guard LSD which does NOT require flanges runs $2595. Unless flanges can be made for less than $400 each there's no point.
1974 914 Bumble Bee
2009 Outback XT
Old 10-19-2017, 06:21 AM
Turbonut
Raceboy's Avatar
I know it is not just cut out and done, it has treated surfaces etc. I consulted with specialists, they said it can be done though.
Old 10-19-2017, 06:23 AM
gearhead
Just to add information for people, the LSD flanges are 61mm to the shoulder, versus 56mm. That's the sole difference
1974 914 Bumble Bee
2009 Outback XT
Old 10-19-2017, 08:26 AM
KTL KTL is offline
Schleprock
KTL's Avatar
So we're talking coarse flanges with CV "cups" that are 4-bolt (the other two are roll pins) and 108mm diameter?
What if wicks decided to swap axles and install the 100mm axles? Of course he'd also need the associated transmission drive flanges and the stub axles. Only reason I say this is because the 100mm axles are quite plentiful used, as are the flanges and axles.
Kevin L
'86 Carrera "Larry"
Old 10-19-2017, 09:32 AM
group911@aol.co's Avatar
Are the 100mm coarse flanges that easy to find?
Thanks,
Bob
group911@aol.com
Old 10-19-2017, 09:57 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Well if he replaces the output flanges when he does the replacment diff, he doesn't need the coarse 100mm flanges? That said, I have two sets of the coarse 100mm flanges. I don't know if that means they're rare or common though. Just saying I personally have two.
One set came in the racecar as-bought, which started as a '79 SC but has an '84 915 transmission. Apparently the original '79 SC output flanges were transferred into the '84 trans with the billet LSD it has in it. I think it's one of the early GT billet diffs. The other pair are from a friend's '79 SC, coincidentally, that had a problem with the trans and he needed to replace it. His trans had an open diff. So now that I think about it, I should take a look at the two pair of flanges and see if they're the same dimensions, just to educate myself
Kevin L
'86 Carrera "Larry"
Old 10-19-2017, 10:05 AM
