Should I put Guard LSD in a 2.2??
Question for the experts - 1970T coupe currently being restored. Stock 2.2 engine is being upgraded to S specs. Transmission is being rebuilt as well and wondering if I should put in a Guard LSD. Stock fenders so tires will be 205 width for now. Suspension hasn't been touched but will next year funds/wife permitting. I will be driving it regularly on the street and occasional track days. It will never be a race car but will enjoy track day events. So is the cost of the LSD worth it? I figured now would be the time but if I'm not going to notice it enough then maybe use the funds elsewhere on car. Thanks in advance for any advice.
3 restos WIP = psycho
I would. The occasional track nails it.
Sent from my Nexus 6P using Tapatalk
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
A question only you can answer. You're technically not going to win or lose a track day so it doesn't matter. However an LSD can improve your experience on track.
Not a cheap decision. FWIW, I installed my LSD with the trans in the car. So you really don't need to decide now. If you button your car up with an open diff, get the track day bug, and are peg legging all over the place you can decide to upgrade at that point. You may find that your track day dreams are just dreams, and the car ends up too nice to drive on track. At that point the LSD would be nice to have, but not really being utilized. The one good thing is that unlike a lot of mods, an LSD has very little negative effect in everyday use. A 911 style clutch diff can occasionally be a little grumpy when reversing out of a parking spot but that's it. A torque biasing diff is virtually invisible day to day.
Matt - 84 Carrera |
Great comments, thanks. Honestly I see 4-5 track days per year max. Not restoring to concours level so I don't feel bad about thrashing it. Crazy how costly even driver level is to get to.
I take it if you had to decide between an LSD now, or upgrading shocks/struts/tbars through Elephant, most would take the latter? |
That's a hard one. Do you not like your current suspension? You can do great work on a track with a stock really suspension. I would probably do they latter first, but it is close. My LSD has saved me enough times I won't do without one in any car now.
I don't really "know" my current suspension as I only drive it for few times on the street prior to deciding on the restoration. It was bouncy in the back but shocks/struts only can be changed easily. Car wasn't driven regularly for several years prior so lots of catching up to do.
How much is the Guard?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Should be around $2200 I believe.
gearhead
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
What type of LSD is the Guard?
I have a spare 915 LSD transmission, which I was thinking of putting into my 77 911 running a 3.2 but its an original Porsche item and measured within the tolerance. Personally once you have had a LSD its hard not to appreciate the extra traction control you gain from it under acceleration and deceleration. Well that what I found.
77 Porsche 911 3.0 Carrera 58 Porsche 356 55 Chevy Bel-Air 72 Volkswagen Bug, 06 Volkswagen T5 14 Yamaha R1, 14 GSXR750, 17 CRF1000 |
Not that I should speak for them, but Guard sells both a Salisbury (clutch) LSD and a torque biasing diff (don't call it an LSD or you'll trigger some people.)
Talk with Matt and he'll recommend the best Guard product for your application and goals.
Matt - 84 Carrera |
It would be this
Limited Slip Differentials | Guard Transmission Good to know its not a hassle to install later once drivetrain is back in.
1970 911T/S coupe Irish green 2013 991 coupe aqua blue sold 1978 911SC Targa Venetian blue/cork sold
I was under the impression that, while great for track driving/ultimate limits, adding a LSD would significantly change a 911's "feel" in day to day spirited driving. Would appreciate clarification/elaboration of what differences one would/could feel day-to-day after adding a LSD
gearhead
The people who use the guesstimate method of install rarely come back a few years later and post about how their ring and pinion failed. Its not gonna break the first time out driving. If done wrong it takes a while to fail.
gearhead
Under the radar
I'd say, if you have the funds AND you will be upgrading to a larger motor, AND you think that maximum braking at a DE is your thing, go for it.
In my case my '71 has a warmed up 3,0 and a 915 and an open diff. I regularly autocross and do a couple of DEs a year. I don't feel a real need for an LSD. I'm not having any problem getting the power down or in braking. YMMV. See my garage for all my car's mods.
Bland
Grady Clay advised against putting an LSD into a low power car (under 250 HP) when Andrew15 and I were building our track cars.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
But as Matt says tuning is a factor. Once on the road most lsd are going to be mostly transparent
Thanks Matt and Bill -- another factor to consider when I start my upgrade journey!
gearhead
