Should I put Guard LSD in a 2.2??
Question for the experts - 1970T coupe currently being restored. Stock 2.2 engine is being upgraded to S specs. Transmission is being rebuilt as well and wondering if I should put in a Guard LSD. Stock fenders so tires will be 205 width for now. Suspension hasn't been touched but will next year funds/wife permitting. I will be driving it regularly on the street and occasional track days. It will never be a race car but will enjoy track day events. So is the cost of the LSD worth it? I figured now would be the time but if I'm not going to notice it enough then maybe use the funds elsewhere on car. Thanks in advance for any advice.
Old 10-11-2017, 05:35 AM
3 restos WIP = psycho
kenikh's Avatar
I would. The occasional track nails it.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-11-2017, 06:23 AM
A question only you can answer. You're technically not going to win or lose a track day so it doesn't matter. However an LSD can improve your experience on track.
Not a cheap decision. FWIW, I installed my LSD with the trans in the car. So you really don't need to decide now. If you button your car up with an open diff, get the track day bug, and are peg legging all over the place you can decide to upgrade at that point.
You may find that your track day dreams are just dreams, and the car ends up too nice to drive on track. At that point the LSD would be nice to have, but not really being utilized.
The one good thing is that unlike a lot of mods, an LSD has very little negative effect in everyday use. A 911 style clutch diff can occasionally be a little grumpy when reversing out of a parking spot but that's it. A torque biasing diff is virtually invisible day to day.
Matt - 84 Carrera
Old 10-11-2017, 06:43 AM
Great comments, thanks. Honestly I see 4-5 track days per year max. Not restoring to concours level so I don't feel bad about thrashing it. Crazy how costly even driver level is to get to.
I take it if you had to decide between an LSD now, or upgrading shocks/struts/tbars through Elephant, most would take the latter?
Old 10-11-2017, 07:18 AM
kenikh's Avatar
That's a hard one. Do you not like your current suspension? You can do great work on a track with a stock really suspension. I would probably do they latter first, but it is close. My LSD has saved me enough times I won't do without one in any car now.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-11-2017, 07:32 AM
I don't really "know" my current suspension as I only drive it for few times on the street prior to deciding on the restoration. It was bouncy in the back but shocks/struts only can be changed easily. Car wasn't driven regularly for several years prior so lots of catching up to do.
Old 10-11-2017, 07:36 AM
Elombard's Avatar
How much is the Guard?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 10-11-2017, 07:58 AM
Should be around $2200 I believe.
Old 10-11-2017, 08:01 AM
gearhead
Originally Posted by nhs15 View Post
should be around $2200 i believe.
$2595
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 10-11-2017, 08:04 AM
KillerDynoSoar's Avatar
What type of LSD is the Guard?
I have a spare 915 LSD transmission, which I was thinking of putting into my 77 911 running a 3.2 but its an original Porsche item and measured within the tolerance.
Personally once you have had a LSD its hard not to appreciate the extra traction control you gain from it under acceleration and deceleration.
Well that what I found.
77 Porsche 911 3.0 Carrera
58 Porsche 356
55 Chevy Bel-Air
72 Volkswagen Bug, 06 Volkswagen T5
14 Yamaha R1, 14 GSXR750, 17 CRF1000
Old 10-11-2017, 09:06 AM
Not that I should speak for them, but Guard sells both a Salisbury (clutch) LSD and a torque biasing diff (don't call it an LSD or you'll trigger some people.)
Talk with Matt and he'll recommend the best Guard product for your application and goals.
Matt - 84 Carrera
Old 10-11-2017, 09:12 AM
It would be this
Limited Slip Differentials | Guard Transmission
Good to know its not a hassle to install later once drivetrain is back in.
1970 911T/S coupe Irish green
2013 991 coupe aqua blue sold
1978 911SC Targa Venetian blue/cork sold
Old 10-11-2017, 12:23 PM
I was under the impression that, while great for track driving/ultimate limits, adding a LSD would significantly change a 911's "feel" in day to day spirited driving. Would appreciate clarification/elaboration of what differences one would/could feel day-to-day after adding a LSD
Old 10-11-2017, 01:05 PM
gearhead
It would be this
We don't recommend leaving the gearbox in the car. It should be done on a stand with the factory set up tools. Backlash is set to .01mm tolerances.
The people who use the guesstimate method of install rarely come back a few years later and post about how their ring and pinion failed. Its not gonna break the first time out driving. If done wrong it takes a while to fail.
1974 914 Bumble Bee
2009 Outback XT
Old 10-11-2017, 01:16 PM
gearhead
That is easily address with lsd tuning.
1974 914 Bumble Bee
2009 Outback XT
Old 10-11-2017, 01:17 PM
Under the radar
Trackrash's Avatar
I'd say, if you have the funds AND you will be upgrading to a larger motor, AND you think that maximum braking at a DE is your thing, go for it.
In my case my '71 has a warmed up 3,0 and a 915 and an open diff. I regularly autocross and do a couple of DEs a year. I don't feel a real need for an LSD. I'm not having any problem getting the power down or in braking. YMMV. See my garage for all my car's mods.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-11-2017, 02:02 PM
Bland
unclebilly's Avatar
Grady Clay advised against putting an LSD into a low power car (under 250 HP) when Andrew15 and I were building our track cars.
Old 10-11-2017, 02:04 PM
Bill Verburg's Avatar
Even an oe ZF 40% is only really noticeable in tight parking lot kind of turns, the later asymmetrics generally run lower preload and are less intrusive in parking lots.
But as Matt says tuning is a factor.
Once on the road most lsd are going to be mostly transparent
Bill Verburg
Old 10-11-2017, 03:16 PM
Thanks Matt and Bill -- another factor to consider when I start my upgrade journey!
Old 10-11-2017, 03:17 PM
gearhead
I 100% agree with this logic. It's what I used when deciding for my old 914. I would suggest the OP drive a few cars with various diffs if possible. As someone mentioned above ANY performance differential will be a night and day difference. For the $1000 savings off of our LSD, the TBD leaves a good chunk on the table to spend on other things.
1974 914 Bumble Bee
2009 Outback XT
Old 10-11-2017, 03:54 PM
