exhaust
Ruf exhaust - made by Alois Ruf. He modified the standard 2-pipe turbo muffler to add 2 more pipes on the other side. I'll take a pic when I do the test you mentioned.
RUF Automobile GmbH – Manufaktur für Hochleistungsautomobile
1986 911 turbo - less than 30k miles |
testing distributor green wire
T77911S,
580 ohms. looks good. Thanks for the suggestion! Now, I am waiting to hear if my CDI tested bad. That would be good news, even though it costs $200+. Just to bore everyone, here is a shot of the Ruf exhaust. I visited his shop 31 years ago after taking delivery at the factory. He took me for a ride in a customers turbo and I saw 300kph on the speedo. A super guy and very solid Porsche solutions.
Certified User
Just came across this thread ... links to my original files are in links setup by Tremelune at post #58 in this thread.
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
Thanks billjam!
CDI tested bad - repaired and in the mail to me now. Fingers crossed!
Thanks to all who replied!
The CDI box was bad. John Walker suggested Ingo (username ischmitz) and he did a swell job. Now, I have to repair 31 year old CV joint boots. It never ends. terry
check the 930 side under jfairman. he found another CV boot that may be better
I had noticed a slight whining sound while on the club tour before the CDI died.
I was hoping it wasn't a rear bearing, as I recently sold my bearing puller kit here. Since the joint may have run dry for a while, I will go ahead and do the kit that has the joint in it. I may pull the engine and work on some oil leaks. Also want to replace the A/C hoses. The A/C was dead when I took delivery and it never held a charge. I don't drive it when it is hot out, but I'm trying not to let things go. My wife understands how I feel about the car. We picked it up at the factory and we also drove it to our wedding. Kinda special.
Stock looks, better performance, fully 'mapable' for ignition timing...
911 CDI+ (6 Pin) - Classic Retrofit
www.classicretrofit.com |
