douglas bray's Avatar
My 3,2 has a MaxHPKit Multi-board, modern Bosch 715 injectors, Bisimoto exhaust, VP Madditive, and I routinely go past 7,000 RPM. I think fuel cut off is 7,200 but on a 30 year old tach, who knows. Car weighs in at 2,740 WITH ME IN IT so redline comes quick in 1st, 2nd, 3rd. I have zero concern. Porsche designed racecars that got fattened up with creature comforts so they'd sell to the public. They are right at home being abused. Sorry, it's the truth.
Old 11-01-2017, 08:46 AM
Banned
Originally Posted by panzerfaust View Post
+1
if you shift at peak hp ie around 5900-6k on a 3.2 your stock 2nd gear will drop you to about 3000 rpm and thats if u want to slam shift it. 3.2 are gutless at 3k rpm... van driving soccer mom would destroy you :-)
i dont even want to think about what the rpms would be if i shifted where the torque is falling off 1k rpm earlier.
if i had a 3.6 i wouldnt need to go over the redline as often
+ 1, for Metzger
Old 11-01-2017, 02:39 PM
Bill Verburg's Avatar
yes... that should pretty much discount the rod bolt/conrod weakness theory.
I always thought the clearances of the valves to the taller euro dome 3.2 piston lowered the rev limit. the CS may have ran with hollow valves for this reason.
3.3 930 larger displacement with milder cams and low cr piston have 6800 redline because you dont have to worry about valve interference perhaps?
can you still order these factory hollow valves? it would be nice during the rebuild.
i take mine occasionally to 7000 where there is a old school abrupt ignition cutout. not the best way to rev limit a car if you are hot out of a corner. throws it out of the balance wants to send you into the weeds.
the DME probably doesn't have a ability to have a "soft cutout" like the moderns. i dont believe the DME cuts the fuel only otherwise the motor might detonate under high load.
M637 intake valve is 930.105.409.14
Ti valves would be lighter
The engine speed is governed solely by the DME's control of the fuel pump which it can switch on or off
Bill Verburg
Old 11-01-2017, 03:00 PM
Here's a graph of 2 different engines in an SC chassis w/ stock SC trans
the stock 3 liter needs to be shifted where the accel curves cross, if the thrust was graphed it would show the same crossing points.the 3 to 4 shift would need to be @5450, the 4 to 5 @5600
The 3.6 curves don't ccroos so this engine would be run to red line for every shift
The whole goal of a shift is to maximize thrust or acceleration in the next gear
Bill Verburg
Old 11-01-2017, 03:11 PM
WP0ZZZ's Avatar
Excellent plot to illustrate the issue.
Old 11-01-2017, 05:00 PM
Holy crap is a stock 3.6 that much stronger than an SC motor?
Matt - 84 Carrera
Old 11-01-2017, 05:39 PM
Originally Posted by ben parrish View Post
Be careful of advice that is so far off that its not funny....the cars have rev limiters. It will not save your engine from a mis shift but it will " bump" to remind you to shift. As Glen said above, It is not wise to fool with a much past stock limit on the factory rod bolts because of stretch but don't loose a lot of sleep over this ...because...there is a rev limiter built into the DME chip to remind you to shift if you are challenged in your attention to the screaming engine...like on a track.
Discussion is great but please be careful of Internet experts that speak with authority but have probably never opened an engine or even know where the DME chip is located.
FWIW - Yes agree 100%, let's not be like other car forums (we usually are not). E.g. I did X to my car and therefore it is OK for everyone - of course these sorts of statements usually come from non-experts.
Sold: 1989 3.2 coupe, 112k miles
Old 11-01-2017, 06:28 PM
Formerly known as Syzygy
Canada Kev's Avatar
That acceleration looks pretty strong, on paper, at almost 25 ft/sec^2. Isn't gravity acceleration 32 ft/sec^2?
Kevin
Old 11-01-2017, 06:55 PM
thanks for the part number... interesting that it starts with a 930?
im not a big fan of Ti valves on an old school street motor intended for high mileage usage. the hollow ones have better heat transfer too but and being factory has been tested for durability.
surprising that its fuel shut off since the cut off is pretty abrupt. i think my chip is set at 7000-7100 for the rev limiter.
Old 11-02-2017, 05:21 AM
yes
both of the dyno plots come from healthy versions of each type
the 3.0 is a bluprinted SC race motor the 3.6 is a blueprinted 993 nvr w/ RS cams/valves & chip
Bill Verburg
Old 11-02-2017, 05:32 AM
Hollow aren't particularly efficient for heat transfer, they fill them w/ Na for that, then use them mostly on the exhaust only
I mentioned Ti mostly because a friend had his 3.0 liter race motor built w/ Ti valves, the thing is a rev monster 8k rev limit
Bill Verburg
Old 11-02-2017, 05:35 AM
im not a big fan of Ti valves on an old school street motor with stock valve seats intended for high mileage usage. the hollow ones have better heat transfer too but being factory has been tested for durability would be an added benefit.
I luv these graphs of yours. I have an opposing view of this respectfully. from the look of the 3.0 it looks to be vitally important to shift out at 1st and 2nd at redline.
what that graph leaves out is the shifting time of the slow 915 box which most likely will fall right on the dip of the 2nd gear curve. anyone who drives these cars can definitely feel this by the seat of his pants.
as you can see from the 3.6, where you shift isnt as important since the next gear falls on steep constant acceleration ramp. in the real world, torque wins over hp/weight for street driving especially with stock gear ratios. but power to weight make you an internet hero despite a huge hole in your acceleration curve!
all the best pf
Old 11-02-2017, 05:44 AM
WP0ZZZ's Avatar
Where you shift in the 3.6 is actually very important.
For example, if you shift from 4th to 5th at 110 mph you go from roughly 9 ft/s2 to 7 ft/s2. In terms of performance, why would you like to upshift to have less forward acceleration? If one holds 4th up to the redline at 120 mph, acceleration is still stronger in 4th than 5th.
The plot shared by Bill Verburg is the ultimate real world performance "metric" since it shows car acceleration in each gear at each car speed. One figure summaries such as max power, max torque, or maxhp/weight can all be useful to convey an idea of car performance but there are many caveats that one should take into account when using them.
Acceleration vs speed plots represent the performance envelope of a car and are very useful in motorsport to optimise car performance.
Old 11-02-2017, 07:01 AM
Don't get me wrong, I run mine to redline all the time, once it is fully warmed up. I just see no point in going past that for the 3.2 engine with a stock transmission. I don't drag race at all. I do my fast driving on the autocross or track events. Running to 6,400 RPM through 1st and 2nd will get me to 60 in enough of a hurry.
On the track at Charlotte Super-speedway was a blast. I would go from the infield up to the banking in 2nd gear and stand on the gas. Run to redline, shift to 3hrd, run to redline shift to 4th run to redline (about 115) and stick it in 5th and cream towards the big curve ahead. I will admit I was a wimp and eased back on the throttle to go through the banked curve in tipple digits. Nail the brakes hard and get back down to 2nd and on to the infield. I don't know what max speed was in my car. The track is about 6 inches wide to my senses even though the pros go through there three cars wide at 200. I did notice above 5,000 RPM in 5th. It was fast enough for me.
I will have to dig to find the photos of that one. Here is me at Lagua Secca.
Old 11-02-2017, 12:30 PM
i dont think so... extra displacement, quicker shifting G50 and broad torq curve over the SC has the 964 nearly always accelerating so it isnt as important to shift near redline as a SC. u can shift a 964 1500 early and still walk away from a sc without trying.
thicker torq curve of the 64 allows more flexibility in were u can shift over sc without as much detriment to acceleration. of course if you want shift at redline on the 64 for max accel, but if you dont it dosent really fall into the hole of the torq or accel curve like that of the sc. hence my reasoning for not having to shift at redline or more as often.
yes look at the graph, the acceleration curve on 964 is nearly constant in each gear till the very end then it dips. if you shift at peak torq as some have suggested in the sc, you are actually decelerating again before the surg in 2nd and 3rd.
old school sc arent necessarily slow but you have to beat em like a step child to get em to move :-)
all the best
Old 11-06-2017, 07:22 AM
WP0ZZZ's Avatar
If one doesn't want to drive that 964 to the maximum of its capabilities then I have nothing to say. There are many ways to drive a car suboptimally
If one wants max acceleration, the shifts need to be just before the limiter.
Old 11-06-2017, 11:13 AM
+1 agreed ! cheers
Old 11-06-2017, 12:22 PM
