Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by Charles Freeborn View Post
I’m not sure why you’re focusing on the CIS unless it is clearly suspect.
I am focusing on CIS, Charles. Not the OP.
OP is a long way away from gauges. He is also a long way away from the Bosch book on CIS as recommended by Tony. Which I have in electronic form.
He needs to understand how the system works. How can the PET manual or a Bosch book written for professionals do that if there is not a lot of prose wrapped around the core info?
I say Bruce Anderson's 911 Performance Handbook, Wayne's book - only because the young crowd says so (I own them) - and Probst's Book.
1981 911SC Targa
Old 12-04-2017, 04:26 PM
Winter reading
Have assembled reading material and gauge
Thanks to all for your advices/suggestions
Jason
'79 911SC Targa
Old 12-09-2017, 07:13 AM
Practice makes you better..........
Jason,
Read and visualize how the instructions are done and performed. It might take you a few practices to make the test works but there is really nothing sophisticated about CIS troubleshooting. Just be aware of several safety precautions involve in dealing with pressurized combustible liquid like gasoline. No smoking, no open flame, no source of ignition near and around your work area that is well ventilated. Have a standby fire extinguisher handy. Better to be safe than sorry.
No matter how good and experience you are, you will commit some mistakes like leaving a fitting loose or a fuel hose disconnected. And I made these blunders so many times in spite of earnest desire to operate safely. The key is awareness and presence of mind.
Do not do any pressure testing until you fully understand how CIS works. Reading the Bosch K-Jetronic Manual again and again will give you a better outlook at things. Good luck.
Tony
Old 12-09-2017, 07:59 AM
sugarwood's Avatar
Are you interested in learning how cars work, in general ? Like how does the Otto cycle engine work? How do brakes work? How does the suspension work? Or do you already know all that, and are looking for details on Porsche engine characteristics?
1986 Bosch Icon Wipers coupe.
Old 12-09-2017, 03:48 PM
I want to familiarize myself with this engine - I've done suspension and brake work on other cars in the past. I'd like to be able to problem-solve the typical issues with our engines, or at least be able to tackle them with the input of others; cold start, warm start, pressure tests, etc.
And thank you Tony for your guiding words above.
Jason
'79 911SC Targa
Old 12-09-2017, 04:43 PM
Location: behind the redwood curtain, (humboldt county) california
You silver tounged devil..
Originally Posted by Brian Cameron View Post
Suck
Squeeze
Bang
Blow
That’s the essence of it
I think the op's question was how does chit work, not what you are doing this evening
Chris
Old 12-09-2017, 05:17 PM
