Oil line hose from engine to thermostat
Hi, my hose crimps are toast so just for fun I cut out the crimps and I see great place for hose and clamps.
The thermostat oil line removal freaks me out so for now maybe I can just replace the hose portion. What size is this hose and where can one buy it? Thank you. Few pics ![]()
1974 911 coupe 4 speed |
what a freakin mess !!!!! ( love the Tims product placement tho )
I don't have a 77 and that does not look familiar at all , but any hydraulic shop like rubberline should have hose and fittings, even be able to crimp your original line.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
I just came back from three shops and none of them have it.
Schleprock
https://www.belmetric.com/smooth-high-pressure-oem-c-14_139/?zenid=h4e75mrrbt6fo8p1k86eesade2
https://www.elephantracing.com/porsche/911/oil-cooling-for-911/oil-lines-hoses-fittings/bulk-hose-and-hose-ends/ Measure the inside diameter of the existing hose. It's likely going to be 22mm. Len the resident oil line guru & fabricator (BoxsterGT is his username) is probably going to chime in here and advise against using basic hose clamps.
Kevin L '86 Carrera "Larry" |
Awesoooooomm
I really don't see a reason why clamps wouldn't work here, the ends are grooved and two clamps on each side will work well. Plus no more concerns about the crimps not holding, just tighten as needed. Off course, I can be convinced otherwise. This thing has been a money pit so far(aren't all cars?) and trying to save some money and not open another task to do as I feel little bit overwhelmed at the moment with all the things I have to do.
Schleprock
Just be sure to use clamps that capture the hose uniformly. I would not use the typical worm gear slotted hose clamps. Use a smooth clamp that crimps. The crimp style clamps afford you some flexibility in that the crimp acts like a spring and can deal with change in temperature and hose size. Whereas typical screw type clamps are fixed and don't "react" well to change in hose size.
https://www.pegasusautoracing.com/productselection.asp?Product=3295 I like the single crimp clamps that have a tongue and groove in their design. https://www.mcmaster.com/#catalog/123/309
You are talking about a hose for the lifeblood of your engine. To use anything but a proper clamp is crazy. It that fitting fails it will dump all the oil in a heartbeat and the engine will not have a heartbeat for long.
Hey, it is your engine, you take whatever risk you can live with. I would not do it with my engine.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Find a hydraulic shop with a Cohline swage machine to do it properly...do not settle for less.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Thank you everyone, I will go with proper oil lines.
![]() I may be able to help. Here is an example of what I offer for a Re-Hose of an original....... ![]() Alternatively, I can send you the loose crimp sleeves and a length of the correct hose if you want to do this locally. Len at Autosportengineering dot com
Hose clamps will work even the worm gear types if you use 2 per connection, one in reverse direction of the other. I had to do this once and it lasted for years. There was a period of time when the after market replacement hose was 1 inch too long (imagine something too long being bad) and the replacement was the same. It create a kink and not a good fit. In a bind, I cut the hose and use 2 clamps.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
