3 in to date... TY Will, Bruce, Johan.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Product's been ordered for test and fire department has been contacted to coordinate their participation. Thanks to Rob for his email input to me---much appreciated Rob.
Best of luck with the test and I hope it goes better than it did for these intrepid racers
![]() https://www.youtube.com/watch?v=_XIw5KZPbxU Last edited by Element Fire; 02-22-2018 at 12:03 PM.. |
Element Fire - do you know if your under seat mount will fit in our air cooled 911s?
The under-seat bracket that we offer is from 'The Bracketeer'. I cannot be sure if it works on the air cooled 911's but the following fitment guide from their website should give you all the info you need to be sure:
Compatibility — The Bracketeer I hope this helps. |
Thanks - I'll go measure and check!
Been here a while
It does fit in the glove box.
looking for 1972 911t motor XR584, S/N 6121622 |
EDIT: Vid is no longer available. (Could no longer edit post post #1 to advise this.)
Am departing country for 3 weeks... right now. Will respond to questions---if there are any---when back home. Thanks to my supporters and participants. Am adding a few zeros to checks. I can finally retire in opulence.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 08-01-2018 at 08:18 AM.. Reason: Vid no longer available |
Uncertifiable!!!
Karl,
What an outstanding video. You have conducted an impressive and thorough test procedure. Worth the price of admission. Not so for the Element-what a disappointment! Have a great trip and thanks again for all the work and organization that went into this project. Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
As Milton Freedman said "there ain't no such thing as a free lunch". Thanks for doing this Karl.
1983 911SC 2005 911S |
Very well done Karl.
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
Nicely done indeed, I'll save mine for when I need to put out a match.
Jason
'79 911SC Targa |
Interesting results - thanks for posting that.
I sent you guys a question via your web site but no response so far. Will you send these extinguishers to Australia via Surface Mail (Ship)? Regards, Frank
76 911S Land Rover 110 Defender |
I would like to see a comparison with the alternative, a small dry powder extinguisher with the same fires.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Cars and Cappuccino
I think it is awesome that a fellow Pelican created this. However, I agree. I need to know the performance of an Element vs. the standard Kiddie bottles most of us cruise around with. (yeah, I will pitch in $10).
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
Coram Deo
Agreed. I wouldn't expect a small extinguisher to put out a big fire. I was actually pretty impressed with the fire suppression part of this.
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • |
Registered Minimalist
Great video. Product doesn't look suitable for an engine fire. Not sure what else would be an appropriate reason to carry this in your vehicle.
It may be similar to a small kiddie bottle, but the blasting distance is greatly reduced. You have to hold this near the source to extinguish. Despite this, I'd keep a couple around - if they weren't so expensive. $100.00 (tax and shipping) for the 50 seems like a lot. I would pay more like $40 given what I saw in the video. Again, thanks for making the video Karl, and to those who supported it!
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
It also looks disappointingly corrosive to aluminum. It was just briefly waved over that aluminum test plate, but if it was left on there longer (like a real fire) the damage would have been much worse.
Doesn't seem any better than a conventional extinguisher in that case. It's small size might make it attractive as a supplement to a Halotron if that runs out before the fire is out? Just carry both? Mark
1979 911SC Targa |
I would like to compliment Karl on his testing initiative and the high production quality of his video. The filming and editing is first rate and the various testing scenarios were well thought out. I also appreciate that he took a 'you judge for yourself' approach rather than offer his opinions which is so often the case with this kind of test. That said I would like to respectfully offer some information to help better understand what is seen in the video.
The fire test was generally well done but did have one significant issue that affected the results. On the larger fires the extinguisher was held too close to the flames to allow the gas to saturate the area around the fire. The technique of getting close and sweeping the base of the fire is appropriate for a powder extinguisher but is not for a gas extinguisher. This applies not only to the Element but also to CO2 or a Halon/Halotron extinguisher. Had the tester moved back a little then the gas would have had the chance to surround the fire and put it out. It was disappointing that a pro firefighter missed that however it re-enforces our need to create the correct educational materials to best prepare our customers for an emergency. One cool thing was that the close proximity to the liquid fire demonstrated that the Element did not blow the liquid out of the pan into a big fire ball as would have occurred with any compressed bottle type extinguisher. Our website has been recently updated with a new Media section that shows more fire scenarios including a car engine fire. In all the videos the people putting out the fires were not pros and had limited or no experience putting out a fire with an Element. They were however told that the goal is to create a cloud around the fire in order to put it out and the results are plain to see. One interesting test that Karl did show in his video was the fire being put out behind the mesh. That scenario perfectly shows how you can point the gas from an Element through a cracked open hood or a grille to saturate an area before opening the hood to finish off a fire. This ‘pre saturation’ will greatly reduce the chance of a flare up when opening the hood because the gas (which is heavier than air) will block incoming oxygen from feeding the flames. Definitely a cool illustration. |
