Need Help with 3.2 Engine Harness
Can someone tell me what this connector would attach to? I've isolated everything else. this is on a 3.2 engines wiring harness.
Thanks for the Help...
Old 02-08-2018, 05:04 AM
old man neri's Avatar
Could you take a better picture? One that shows what the mating surface of the connector looks like? Also, is it two or three wires? It's hard to tell if one of those wires is for that spade connector underneath.
Old 02-08-2018, 05:31 AM
Sorry about the pic. 3 wires going into the connector, black / black/purple / yellow..
cant get another pic till Friday.
Old 02-08-2018, 05:56 AM
02 sensor?
Old 02-08-2018, 06:28 AM
Looks to be the connector the connects the DME to the dash assembly. Yellow connects DME pin 4 to Ignition starter switch pin 50, Black and Black/Violet connect DME to Tach. Black goes DME pin 11 to Tach pin 1 and Bk/Vi goes DME pin 21 to Tach pin 2. From factory wiring diagram: I think you are looking at connector Item # 59 which is located on diagram page 6 in grid F33.
Old 02-08-2018, 06:41 AM
Awesome. Thanks for the info....
Old 02-08-2018, 06:48 AM
