Ok I don't have a parts number manual so I need your help. I have a short block that has the numbers 901.101.101 OR on one side and 901.101.102 OR on the other side. I would imagine the 102 is for the side designation but what size block is this. Is there another number I should be looking for also.
Thanks to all who answer |
Most likely a 2.0 but post the number on the that is by the fan shroud, ie 901/##
Robert |
The number by the fan shroud is 3280442.
Monkey with a mouse
![]() Quote:
Should match a 902/0 tranny. Chassis numbers matching this motor should be 11830001 thru 11830473. 473 of these Porsches in this configuration were produced, each weighing 1080kg. Hope this helps! Regards, Kurt |
Thread Tools | |
Rate This Thread | |
