Any adapter for big cigerette lighter socket
I've been searching with little success to find an adapter to properly fit a smaller US accessory charger plug into the larger cigarette lighter socket of my 911. I'm tired of fiddling with plastic gaskets, tape and rubber washers to try to get a snug fit and not have my phone charger falling out after every bump. The home remedies just aren't doing the job.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
cig
Me too..
1978 911sc cpe 1986 944 N/A sold to pelican 1965 series 2a 88 landrover sold 1964 series 2a 88 landrover sold 1988 944 white. sold |
RatShack
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
I "pulled" the side prongs out a little on my GPS charger and it works great.
Insert a tool of sorts between the prong and the charger body, then just pry the prongs out a bit. I believe I used a flat blade screwdriver, inserted it flat and then turned it just a tad. The prong will have more "arch" to it when done.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
I swapped mine out for a universal replacement but used the original trim ring and knob (requires some adapting). It looks completely stock but adapters fit and replacement elements (as a non-smoker I'll never need one) are cheap.
regards, Phil |
As mentioned, R Shack has a "bushing" to take up the slack. Or did.
Senior Advisor
twenty five bucks for a new Porsche one
08 Cayenne Turbo |
I've searched Radio Shack, local AT&T cell phone store, Fry's electronics, and did not find any simple adapter at any store or even online. There has got to be something out there with as many European cars and American gadgets that are out there!
I'm not interested in switching out the whole socket since I heard that was tricky to get out. Also permanently modifying the plugs is not acceptable since I want to be able to use them in my other car which has the smaller socket. Pulling out the side prongs on my GPS doesn't seem possible without breaking something inside.
Senior Advisor
Sounds like you talked yourself out of options, good luck with a fix.
08 Cayenne Turbo |
Been here a while
I'm quite certain you can make something, if you are handy....maybe use an old 35mm film canister as a start, you really just need to find that sweet spot where everything makes contact, then make a sleeve that keeps the plug in that spot, notch the sleeve around the contacts for your device, slide it on when using it in the 911.
looking for 1972 911t motor XR584, S/N 6121622 |
Mine works just fine. You can unscrew the end cap and see what it looks like.
I too can use my Iphone charger and GPS in mine. Luck of the draw, I guess. The film cannister idea for a shim, is a good one.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
I read that Belkin adaptors are a little fatter and fit better, so I bought this one on ebay (search for "New Belkin Micro Auto Car Charger For iPod iPhone #9868") which is a plug in for usb. For $2.99, I can't go too wrong as most things accept usb.
72T Sepia, Irish delivery car ; '16 Cayenne Gone ... 73E Targa - Grey/Beige ; '90 964 C2 - Samtrotmetallic (Gina, the Lipstick Lollobrigida) |
RETIRED
The shim I got with my V1 works great.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Caveman Hammer Mechanic
Hey
2 or 3 short strips of electrical tape stuck 90 degrees and in between the spring contacts of the plug works great. The tension is adjustable by adding or subtracting a piece of tap from either side. I made my first piece of tape shorter, and increased the length of each successive piece slightly longer, creating a ramp effect. Problem solved! eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Do you think this would be a plug and play fitment?
https://www.*************.com/product/PK9X6LIGHTER.html
1979 911SC Euro Tub/1982 Euro 3 Liter PCA E Class Race Car 1985 911 Carrera Coupe-Grand Prix White/Red |
ROW '78 911 Targa
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 03-14-2018 at 08:05 AM.. |
I believe Porsche's official nomenclature is Cigar Lighter...
I think that maybe I'm dreaming.. |
I'm using a Belkin Micro Auto Charger F8Z445. It works well but sits a little deep into the socket.
