Send a message via AIM to smessing
Replacing Pedal Bushing and Clutch Cable. What else should I do?
I have a stiff clutch pedal so I will be replcing the pedal bushings and the clutch cable. Is there anything else I should replace while i'm doing the job?
Thanks,
Scott
Scott
1980 911SC
2019 Ram 1500 Limited
2011 VW GTI Autobahn
2003 Chevy Avalanche
Old 04-13-2018, 10:20 AM
pedal cluster rebuild? Is that what you mean by Pedal bushing? That and return spring and omega spring. Those are all you can do outside the box
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-13-2018, 10:22 AM
Yes, I'm rebuilding the pedal cluster. Will replacing the Omega Spring help to eliminate the stiff clutch pedal?
Scott
1980 911SC
Old 04-13-2018, 12:12 PM
Just make real sure the new cable is straight and does not rub on anything. How old is the clutch itself? There is a proper routing for the cable. Take notes.
Old 04-13-2018, 12:22 PM
Thanks, I replaced the clutch when I rebuilt the engine about 9,000 miles ago.
Scott
1980 911SC
Old 04-13-2018, 12:32 PM
proporsche's Avatar
Hi Scott..there is no reason to replace the Omega spring unless is broken.To help your clutch you should..
1.remove the clutch arm and make sure it is well lubricated after install 2 seals on it
2.clean the Omega spring
3.remove the shaft on the clutch arm and inspect the shaft bearings and lube
4.replace the clutch cable.
5.if you do not have any play in your pedal cluster just remove and clean
and finally how old is you clutch itself??
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-13-2018, 12:36 PM
Thanks Ivan, I replaced the clutch about 9 years ago but put on less than 10,000 miles.
Scott
Scott
1980 911SC
Old 04-13-2018, 02:36 PM
Dr J's Avatar
Make sure you inspect the shaft that the pedals go through. At the clutch cable end I had the bushing wear out and it elongated the hole. Definitely go with bronze bushing. I did this about 5 years ago but recently had the roll pin that holds the clutch pedal crack on me.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 04-13-2018, 02:43 PM
