Send a message via AIM to tmblackflag Send a message via Yahoo to tmblackflag
Barely passing smog
My car has barely passed smog since i purchased it some 6 years ago. I have all records and it looks like the only thing that was changed was an O2 sensor a while back.
Looking at my results (hyperlink below) is there any common knowledge on what needs changed? Cat converter? O2 sensor again?
I should note that when the car starts, for the first 1-2 minutes it smells like exhaust. This persisted even after the top end was rebuilt about 10-15k miles ago.
https://imgur.com/a/tR7dL
1986 3.2 Meteor Metallic Grey
Old 04-16-2018, 04:41 PM
High NOx is indicative of high combustion chamber temps or a failing catalytic converter. Based on the CO and HC numbers, I'd say the engine seems to be running pretty well. The NOx bed is separate from the CO and HC bed,and can fail independently of one another.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 04-16-2018, 04:52 PM
The top end was done after the smog i posted and engine runs even better but the NOx numbers are similar. So you're saying a new cat is likely the culprit? Does that jive with the smelly exhaust on startup symptom?
Old 04-16-2018, 04:55 PM
I failed due to NO up here in the SF area. Your NO readings are worse than mine, but everything else looked reasonably similar prior to my failure a year ago.
A new cat (220K on the original) basically cleaned it all up: NO, HC and CO all look really good now.
Original Cat
New Cat
~Brian
1987 911 Carrera
Old 04-16-2018, 05:03 PM
You barely passed smog? Are you kidding?????congratulations! You passed!!!!!!!! You should be dancing in the street!
Old 04-16-2018, 08:30 PM
Smog is due mid-may and you can see my NO numbers are ridiculously close to failing. I'm just trying to get ahead of the problem and hope the exhaust smelling on startup for the first 1-2 minutes goes away at the same time.
Old 04-16-2018, 08:32 PM
I was just having fun. I’m glad you passed. I just failed a few weeks ago but a complete tuneup with a new 02 sensor and 40 pounds of air in the back tires and I passed!
Old 04-16-2018, 10:40 PM
Cars and Cappuccino
tdw28210's Avatar
Is 1975 (and newer) the cut off year for Cali smog tests? You guys out there have my sympathies. Fortunately, the Porsche bug didn't bite me until after I left San Mateo for the East Coast.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 04-17-2018, 05:06 AM
Chain fence eating turbo
Do you run the crap out of it to get the engine nice and toasty before testing?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 04-17-2018, 05:25 AM
I had similar startup combustion smells prior to replacing my cat, and they're all gone now. After 220K on the original, all the catalyst had basically disintegrated.
~Brian
1987 911 Carrera
Old 04-17-2018, 07:56 AM
Vintage Owner
Jack Stands's Avatar
I think 1976 is the first year for California testing. Here in Illinois they go back to 1996 (when OBD2 came on board) and just plug into the computer port. No sniffers required.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 04-17-2018, 12:17 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Smog test.
My approach to the test is to disconnect the oil cooler fan
which activates at 210f, and run the oil temp up to about
230f during a "spirited" freeway drive.
Then, leave the car running until the very begining of
the test.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-17-2018, 05:02 PM
Location: the bluest city in the bluest county in the bluest state by the bluest ocean...did I mention the blue skies???
This is a re-run of my experience last month to pass smog. Also NO was just barely to high "FAIL".
I went ahead and bought a new, quality, CAT, and passed with near zero's, across the board. Now, coughing up $800 every few years for a CAT, (they don't last like the 'original' ones) is awfully expensive. CAT bypass anyone, and save the CAT for every 2 years test ????
Greg....PCA, 356 Registry, 912 Registry
1977 911S Targa with 3.2...1960 T-5 coupe
1968 912 coupe, that's 32 P-cars, so far...
1990 Chevy 4x4 2500 pickup (with 255K & still rockin')
Old 04-17-2018, 08:58 PM
Dang darkbeer that sucks. How long do they last? just got mine back today and will get smogged this weekend.
Old 04-20-2018, 01:56 PM
