Dumb injector o ring question...sorry
I am in the process of replacing the 6 intake gaskets on the passenger side of the motor. While removing stuff I pulled off the fuel rail and pulled up and pulled all three injectors out. Injectors are fine but I want to replace the bottom o rings before going back in. . My question is, why are there 3 regular o rings in the kits that I bought from Pelican? I understand the one on the bottom, and the one for the top if I was going to replace it, But what about the third o ring. Also, do I really need the new yellow hat and the skinny gray plastic ring? i cannot find much info on replacing the injector o rings. Please forgive me, I'm learning as I go along. BTW, in the 7 years that I have owned my car the hardest thing I have ever done on the car is trying to remove the fused paper intake gaskets on the head!! Gaskets from Hell. But, slowly getting them off. I am getting all vacuum leaks fixed before I move on to other problems. Thanks, Nick
Old 04-29-2018, 01:51 PM
Hi
Targa Me's Avatar
If you remove an o-ring, replace that o-ring.
If you remove the yellow hat, replace the yellow hat.
If your injectors don't use the skinny gray plastic ring, don't worry about it.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 04-29-2018, 02:04 PM
Thanks!!
Old 04-29-2018, 02:25 PM
