New starter now I have ignition problems
I just replaced the starter on my 77 911 race car and now the engine will not fire. The car was running fine before the starter replacement. I have an Electromotive dual spark set up. The engine turns over and there is fuel in the carbs, but no fire. I have power at the electromotive four pin connector from the starter post. Ideas?
George
74 911 Racer
08 Spec Cayman Racer
76 914 Cruiser
Old 05-26-2018, 09:25 AM
Hi.
A tip: you should not provide power to the Electromotive from the starter, get it directly from the battery, more reliable and safe for the electronics inside the Elctromotive unit.
Regards
Eskild
Old 05-26-2018, 10:10 AM
Banned but not out, yet..
RSBob's Avatar
Was the old starter toast or did it somewhat work? If it did work, you might swap it back to see if the issue goes away. Did anything else change with the install? How are your grounds?
Old 05-26-2018, 10:11 AM
The old starter was working...I am checking the ground. If that doesn't work, I will replace to old starter. Stay tuned!!!
George
74 911 Racer
76 914 Cruiser
Old 05-26-2018, 10:23 AM
I reinstalled the old starter and it worked...fired up. I put the new starter back on and it DID NOT fire up.
George
74 911 Racer
76 914 Cruiser
Old 05-26-2018, 11:19 AM
RSBob's Avatar
Sounds defective. May want to contact a shop that can test it.
Old 05-26-2018, 06:51 PM
Maybe the new starter pulls too much power and the ignition can’t fire on what’s left? Maybe check voltage while cranking.
Rutager West
Old 05-26-2018, 07:21 PM
El Duderino
tirwin's Avatar
This may be a stupid question but sometimes stupid questions helps to clarify the problem. You're sure the new starter was turning the engine over, right? I'm only asking because I've seen threads where people had issues when changing starters motors where the new pinion was not fulling engaging the ring. Any way you could bench test the new starter?
Assuming it's not a mechanical problem with the starter motor, that only leaves electrical. In that case, I think Rutager may be on to something.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 05-27-2018, 05:25 AM
Yes. The motor is turning over with the new starter. Maybe I can use another battery to fire the ignition.
George
74 911 Racer
76 914 Cruiser
Old 05-27-2018, 07:45 AM
I would use the second battery as a test.
George
74 911 Racer
76 914 Cruiser
Old 05-27-2018, 09:31 AM
T77911S's Avatar
the starter has the cable from the battery AND the cable from the alt. did you connect the ALT back up to the starter.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-29-2018, 07:56 AM
Yes. The alternate wire and the battery wire are attached. The ignition wire is also attached at the starter terminal.
George
74 911 Racer
76 914 Cruiser
Old 05-29-2018, 08:33 AM
T77911S's Avatar
do you have spark
any ground wires you may have removed
RACE CAR:: sold
Old 05-29-2018, 10:55 AM
