Can I use a 3.0 case with 3.2 internals?
I have a 3.2 motor in need of a rebuild, and looks like it will need a new crankcase. Can I use a 3.0 case with the 3.2 crank, oil pump, intermediate shaft, distrubutor and all the other fixings attached to the case, or do I need to find a 3.2 case?
I've done some searching and investigating but can't find anything conclusive. Bearing sizes all seem consistent based on what I see in the tables in the back of Wayne's engine rebuild book, but that's about all the concrete data I can find.
Thanks for any help.
Bill
Old 05-26-2018, 12:44 PM
A late 3.0 case that was the new future 3.2 case or a turbo case will work for you.
You really need the locators for the flywheel sensors on the two o’clock position.
The one on top is not necessary
The earlier SC cases need the modified oil drain area with the depression to clear the oil screen.
You would need aluminum welding to build the boss for the flywheel sensors, but you have a templet for the welder for comparison
Bruce
Old 05-26-2018, 08:02 PM
Good point on the sensor mounting bracket. I do plan to re-use the Motronic system so this will be an issue.
Thanks!
Bill
Old 05-27-2018, 07:44 AM
Still here
pmax's Avatar
Interesting.
Which are the late 3.0 case ?
Old 05-27-2018, 10:11 AM
proporsche's Avatar
..The late case we used to call them,911 SC 1983+1/2..which has the drain plug from side.
No sump - strainer plate..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-27-2018, 10:27 AM
Bruce
Just when I start to think I know a good bit about Porsches, I read a post like this and know that you have probably forgot more about Porsches than I will ever know.
Old 05-27-2018, 11:45 AM
lake wales fla
Thanks!
Bill
hi bill, it took me a while to find this pic, i knew i had taken it during the build. engine is a 80 sc built to 3.2SS with motronic dme setup. the mounting boss and minor case machining will be your biggest mod to use an sc case in your build project.
Old 06-10-2018, 05:07 AM
That's awesome, thanks for posting that photo. My 3.2 case is probably fixable according to Ollie's but good to know if I can't use it then a 3.0 could be adapted.
Bill
Old 06-12-2018, 09:04 AM
