Senior Member
Superman's Avatar
Rear Window Defroster Current Question
The Bentley schematic is wrong, both for the '78 I have now and for the '83 I once had. The schematic shows a single wire that energizes the rear window defrost wires in the rear window. In reality, the system is two-stage. Nineteen conductors mounted into the glass, total. The middle 9 are in one circuit. The top 3 and the bottom 7 are in a different circuit. The fuses (one to supply the outside rear view mirrors and the other to supply the rear window) are 25-amp, which scares me because of what I want to do.
There is a spade conductor broken off from the window, making it impossible to energize both the top 3 conductors and the bottom 7 at the same time. I could make it all work if I can use a single wire to energize the top 12 conductors at once.
Bottom line: Each of the rear window defrost "+" wires (for the two circuits) energizes at least 9 of the window conductors (one energizes 9 conductors embedded in the glass, the other wire energizes 10 conductors). My plan is to repurpose one of those wires (part of the chassis electrical system feeding the rear defroster) to feel 12 defrost conductors embedded in the glass.
I don't think that is too much to ask of a wire....is it? The wire is at least 12 ga, it appears. I could measure the resistance of the combined 12 defrost conductors, if necessary. IN fact, I could calculate the resistance of each conductor. Again, the factory designed this wire to handle 9 of the defroster conductors in the glass. I think it could handle 12 conductors. Anybody have a concern about that?
Mocha 1978 911SC. "Coco"
Old 05-28-2018, 05:55 PM
Senior Member
Superman's Avatar
For the electricians: I've got automotive voltage (12-14 V) going into a circuit with 1.8 Ohms. How much current is this? The fuse is 25A. Will this tax that fuse?
Old 05-28-2018, 08:38 PM
Senior Member
Superman's Avatar
It looks like this might be 2.79 amps. If so, then I think I'm good.
Old 05-28-2018, 08:41 PM
schoward's Avatar
No but I wonder if the 3 pack will seem to get more juice and defog than the 9. My system works but I notice the bottom 7 section seems to be the weakest, paired with the top 3. I remember someone saying electricity takes the shortest path (or maybe least resistance), so both hooked up may result in the shorter grid getting more action. Nothing much you or I do if the case - just how it is. Go for it.
Scott
1981 911SC Targa - Platinum Metallic
Old 06-03-2018, 12:20 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Snowflake,
I = V/R, so 14V/2.8 ohms = 5 amps. If that's all that's on the circuit, you are golden.
The Targa window has two lugs on each connection on each side of the window, which makes it possible to piggy-back two wires onto the one side of the lug if the other is broken. I assume (by your lack of bragging about having a Targa) that you have a Coupe. Are the lugs arranged the same way on your window?
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 06-03-2018, 01:23 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Defogger relay.
You have what is known as a two stage rear window defogger.
The defogger elements are basically a short.
And, the top and bottom elements are a parallel circuit.
R1xR2/R1+R2= Total resistance.
pm me as needed.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-03-2018, 02:12 PM
