Instead of dash clock
My dash clock doesn’t work.
What is typically this gauge replaced with if one doesn’t need it?
Digital gauge clock? Red rpm light?
Wondering what are the options out there.
Thank you
1974 911 coupe 4 speed
Old 06-06-2018, 06:08 AM
Flojo's Avatar
you can macguyver whatever you like... fix the clock?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 06-06-2018, 06:20 AM
Jacksonville, Fl
There's some cool ideas floating out there. I've seen people put AFR/o2 gauges, added dash vent. I cant remember who exactly, but one member did a alternator warning light that looked really cool imo.
I'm partial to the clock myself, but mine still works....at the moment
EDIT: I was actually thinking of the Low Pressure Warning light by Patrick motorsport. Probably a bit much for a street car..
http://www.patrickmotorsports.com/part/low-pressure-oil-indicator-gauge-warning-light-911-912-914-930-964-993/
Alex
Jacksonville, Fl
'88 Carrera, Guards Red
Old 06-06-2018, 06:31 AM
Cairo94507's Avatar
Is your car otherwise stock? If so, send the clock out for repair. If not stock, put whatever you like in that hole.
'71 914-6 #0372
'17 Macan GTS
Old 06-06-2018, 06:51 AM
Vintage Owner
Jack Stands's Avatar
A lot of racers put an oil pressure warning light in that spot, but I’d also recommend simply getting the clock fixed.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 06-06-2018, 06:57 AM
proporsche's Avatar
this was here before but i will show you again.One of my friend had this clock in his 911.Some genius made .So got him original and kept this one..i think is funny and always correct time ;-)
Ivan
looks original
but it is not
1985 911 with original 502 191 miles...808 198 km
Old 06-06-2018, 07:07 AM
Spiderman
Jesse16's Avatar
There are threads where I've seen a combo gage of items not currently in your cluster.
Have seen 3 items grouped. Voltage and AFR come to mind. Clock maybe as the third is still nice to glance at when at the track lapping.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 06-06-2018, 08:30 AM
Jacksonville, Fl
Or if your into the RS "less is more" thing...
Alex
Jacksonville, Fl
Old 06-06-2018, 09:02 AM
Thank you.
Yes I don’t care about GE clock I want something else, something cool.
It’s a street car.
Maybe rpm shift light.
Old 06-06-2018, 10:20 AM
froggert's Avatar
I put the low oil pressure light from Patrick Motorsports in that spot after getting tired of seeing the broken clock read 9:11 all the time. It's a street car that hopes to grow up to be a race car one day.
Old 06-06-2018, 11:06 AM
Spiderman
Jesse16's Avatar
For me personally it wouldn't be the best place for a shift light as its not really in my line of vision. If the shift light thing is huge, them maybe it would get your attention regardless. Hope it has an on/off switch. Might get annoying if driving the car on the street.
Old 06-06-2018, 11:12 AM
Old 06-06-2018, 11:25 AM
'73 911 T Targa
I sent my clock to North Hollywood Speedometer and had it converted to quartz.
It's indistinguishable from the original, (except that it works : )
Old 06-06-2018, 11:32 AM
I would rather be driving
jpnovak's Avatar
pull the clock and resolder the low temp solder fuseable link. Takes less than 5 min to remove cover and fix. Then have a working clock again.
Old 06-06-2018, 01:56 PM
kavadarchi -- the issue you're going to have with something like an upshift light is that you'd need something to trigger the light -- on a carrera, this is built into the DME, don't think there's an equivalent on the cis engines (FWIW, I disconnected my carrera's upshift light as it was programmed to upshift for maximum fuel economy and was more of a distraction than a feature) -- as you get more familar with your targa, I suspect you'll find that you'll "feel" when it's time to upshift, as you'll run out of power as you hit the redline -- further, damaging overrevs generally are the result of a missed shift (selecting second instead of 4th) sending the revs WAY up over 10k, rather than simply not shifting at redline . ..
Old 06-06-2018, 02:11 PM
Got it, thank you for all your feedback.
I never Ted line the car anyways but was looking for something “cooler” instead of a clock.
Old 06-06-2018, 03:46 PM
7783911's Avatar
A voltmeter is a smart investment
Old 06-06-2018, 06:18 PM
Senior Advisor
James Brown's Avatar
wow your friends with a Singer clock!
08 Cayenne Turbo
Old 06-06-2018, 06:28 PM
Under the radar
Trackrash's Avatar
Here is my option.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-06-2018, 06:48 PM
SoCalSK8r's Avatar
I put my remote display for my V1 there
‘84 Carrera, heavily modded
Please follow me @chopped_up_fitness
Old 06-06-2018, 08:48 PM
