Griznant's Avatar
What comes in a "caliper rebuild kit"?
A very quick question: Do the little rubber O-rings between the two caliper halves come in the caliper rebuild kit?
If not, does anyone know if these are available separately, or what I can get to replace these?
Thanks,
G
Old 05-13-2004, 05:35 AM
abit off center
cgarr's Avatar
No they dont, did you already take it apart? I was told to never split a caliper, maybe because those O-rings are not available?
Craig
______________________
Craig
G2Performance
Old 05-13-2004, 06:07 AM
Griznant's Avatar
Yeah, I split it apart. I had some spacers made to run these with vented rotors. So far so good, but I need a second set of O-rings. I'm sure I can find something to fit it somewhere. Thanks for answering my question!
Later,
G
Old 05-13-2004, 09:33 AM
Morrie's Avatar
Griznant,
I would be very curious to see some pics of the caliper halves split, and the spacers you have. You are a brave man!
Morrie
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S
Old 05-13-2004, 12:50 PM
Griznant's Avatar
I'll see if I can take some pictures. From what I understand, the factory didn't do anything very different from this, and I've seen it done on a 914 before.
I have access to some pretty state-of-the-art model making equipment, so creating a Pro-E file, and sending it to the CNC mill was no big deal. Turned them out in no time.
I'll work on the pictures. So far, I've got them all put back together (minus O-rings) to check fit, and they work like a charm. Now, if they hold fluid is another matter entirely.
Later,
G
Old 05-13-2004, 12:55 PM
Griznant's Avatar
OK, I loaded up some pictures of my caliper modification. So far so good, and everything is up and fits. Now, to finish the front suspension, bleed the brakes, and see how it works.
I'm not sure if the rubber O-rings I got are going to like brake fluid or not. I had a hard time finding something that would work, and then putting it in place. If it starts to leak, I'll have to source something different. I am still using the stock ones on the other side of the adapter so there are basically 4 O-rings in each caliper (which doubles the potential for leaks, I know).
Check my profile for pics:
http://www.pelicanparts.com/cgi-bin/pmpre/pm.cgi?login=Griznant&ID=50581&ID=50581&action=display
Later,
G
Old 06-01-2004, 08:17 AM
atlporsche's Avatar
measure your o-rings, then compare to what mcmaster-carr has to offer...
sjd
Porsche sold, moving back to muscle cars for a bit.
Old 06-01-2004, 08:53 AM
