What to do about rust?
the suspension pan on my 912 was rusted out as ere parts of the surrounding fender areas. I cut out all the heavy rust and plan on replacing it with home made pieces. Is this an acceptable solution? thanks
Old 08-09-2004, 07:59 PM
the pieces are 16 gauge steel. pretty close to the factory metal.
heres a pic of my nearly complete engine also
Old 08-09-2004, 08:01 PM
Old 08-09-2004, 08:22 PM
hkspwrsche's Avatar
Same gauge steel and hopefully the same properties? where did the steel come from? Looks to be acceptable. It mgiht require more corrosion protection since the replacement panels have an electri-coat primer that is easy to scuff and coat. Use weld through primer as well.
Harold
Harold
Old 08-10-2004, 08:41 AM
has any one had any experience with using a cold galvanizing compound instead of a weld through primer. I am just asking this because I can't find a local store that carries weld through primer. thanks.
Old 08-10-2004, 01:52 PM
abit off center
cgarr's Avatar
Not on sheet metal but back in my youth I installed chain link fences and all of our welds were coated with cold galvanizing compound which still looks good after 30 years, oh in Michigan too.
cg
______________________
Craig
G2Performance
Old 08-10-2004, 02:59 PM
Green 912's Avatar
I have made all kinds of little bits and the like. Weld through primer is a must. Grangers or McMaster Carr has it.
Cold galv is made with zinc. Zinc is very toxic when welded and also interferers with the weld.
Old 08-14-2004, 04:29 PM
C. Clark's Avatar
John,
I think you should be commended for your ingenuity, many would have bought replacement panels and alike, or hacked it up in some way. I understand Por 15 is a good sealer for problematic rusty areas. I used a commerial brushable seam sealer, get it at a (automotive paint store),and undercoated everything heavy. It's been two years and all is well, I live in Northen Ca. and drive in the rain...sometimes.
Chas.
63/356
69/912
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 08-14-2004, 06:32 PM
