66 912 starter problem
i have a 1966 912 and today the starter selanoid went completely out on it. it doesnot even make any clicking noise. i have checked the electrical system for any voltage issues and i did not find any.
where is the best place to buy a new/reman starter selanoid
and where the hell is the damned thing???
thanx
herbd
Old 08-31-2007, 08:30 PM
C. Clark's Avatar
Try here or Stoddards.com or http://www.classicandspeedparts.com/
it's on the passenger side of the car near the tranny...............that's the rear of the car.
Chas.
356
912
911
Old 08-31-2007, 08:47 PM
starter deal
It may be worth checking out your local auto supply store. Mine had re-manufactured Bosch units for $39 bucks!! I bought 2!
joe
'68 912
'64 356 Outlaw
'63 356 shell......?
Old 09-02-2007, 03:54 AM
That was the complete starter....not just the soleniod!!
Old 09-02-2007, 03:56 AM
912 Geek
Before you buy anything, diagnose the problem, which could be as simple as a bad ground connection (a battery terminal or the body-to-transmission ground strap) or a bad ignition switch/connection.
If the fault happens only when the car gets hot, it's a known 912 problem, usually caused by a combination of the above. There used to be a relay kit to feed full power to the solenoid; Performance Products used to sell them.
Does the ignition system have power? If so, see above. If not, look elsewhere.
Frank
Old 09-15-2007, 01:55 PM
There is also a yellow that connects to the Starter that can come loose or needs to be cleaned.
Old 09-16-2007, 09:22 AM
