1976 912E rear sway bar
Does anyone know if the 912E came stock with a rear sway bar ? If not was it an option ?
I would imagine that the 1976 911 must have had a rear sway bar and would like to think that if I procured one from a 76 911 that it would correctly mount to the 76 912E. Any thoughts or experience on this ? thanks Dennis |
Yes, the factory rear stabilizer was an option. Any rear stabilizer from 74 on should work. You will need to buy everything; so it would be best to buy a new rear set. also you will need the factory templates to weld the pieces and the pin in the trailing arm.
There are some after market companies that make rear anti-sway bars. |
1976 sway bar
Jaems, thanks, I'll look into it. Dennis
Check out this posting on the 912bbs.org: 912 Board - Viewing Topic: Transmission Mount Deadweight
Free will is doing what we must joyfully. Jung '68 912 Coupe '82 SC sunroof |
If you don't want to weld there are kits that bolt on as well ( C-bolt around the torsion tube, etc. )
here's one aftermarket product; Weltmeister has been around quite a while http://www.weltmeister.com/ProductDetails.aspx?productID=358
Rick Becker 912 owner since 1977 PCA 912 & 912E Register Advocate, 912 Registry Member #0001 http://912register.pca.org | www.facebook.com/PCA912Register | Twitter: @PCA912Register Last edited by Rick Becker; 05-30-2010 at 07:13 PM.. |
Sorry, wasn't aware that the 912E carried a 11 lb weight under the transaxel mount. Otherwise any 74-on rear factory stabilizer would of worked.
Max Sluiter
So, why doesn't every owner remove it?
I would.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
912E rear sway bar
Thanks for the help guys. I think I'll look into the Weltmeister kit. Dennis
