Oil Temp sensor
I have problems with my oil temp system. The black and green wire is disconnected from the back of the gage, but there are no free terminals to connect it to. I assume that the gage is connected up wrong. Does anybody have any idea which terminal it should go to?
At the other end of the system I cannot locate the temp sensor fitting. I have an oil pressure sender behind the distributor with a single green wire which turns off the green idiot light when I disconnect it. Is this a dual purpose sender?
Any enlightenment will be appreciated.
Danke..........Ron
Old 11-04-2002, 09:34 AM
Duke's Avatar
Porsche Crest
On my 69 I have a oil pressure switch & oil temp sender located right next to it. Not sure about the color of the wires on the dash gauge though.
Old 11-04-2002, 11:00 AM
Look at this thread
gauge wires
The green/black is there in the pix. Maybe this will help
GoodLuck
Brett
Old 11-04-2002, 01:52 PM
Little More Info
Do you see the black/green or the green/black
black/green= right turn sig
Green/black= pressure unit. Straight shot,gauge to unit
GoodLuck
Brett
Old 11-04-2002, 02:15 PM
Alan.UK's Avatar
Hope this helps.
You can see the green and black wire on the temp guage. You can also see the blue/yellow and also the brown earths.
Alan.UK
Old 11-05-2002, 05:13 AM
