I have a complete, original 912E motor with all of the original engine tin, no serial number on case, mount, flywheel, pressure plate and disk.
Anyone restoring a 76 or installing a Raby / performance type 4 motor on an earlier 12 could use the tin. |
aka: 'euro911'
Sending you a PM ...
... Mark S. So. Cal, USA Early 911 '232 Registry' Participant 911s, 912s & 914s aka: euro911 on the other car forums
aka: 'euro911'
I sent you a PM a while back, but never received a reply. Are the tins still available?
Thanks ...
gearhead
You need just the tin or the engine too?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
aka: 'euro911'
Already have a motor, Matt. Pretty much just interested in the tin parts (enough to install a T4 in a 67 912)
However, do you have a rear engine mount bar and a working alternator w/ the mounting bracket? If you can post pix that would be great
gearhead
Pm me an email address and what you think it is worth.
