echecsqueen's Avatar
vent window won't open
Hi 912 ers
I have a 1966 912 (newly acquired) that has been modded into a R style. The vent windows look fully operational, but the levers won't move at all. There may be a tiny pin in them. Is this a known thing? Is there a way to make them operational again?
Also, the driver's window goes down easily, but wants to go off track going up. Is there a simple fix for this? The felts feel okay...
So excited to be a fellow 912 owner
the queen
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 06-17-2017, 07:35 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - take a look at the link below in regards to the window being problematic.
Porsche 911 Window Regulator and Motor Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Old 06-19-2017, 10:46 AM
Good looking 912 Queen!
The pre-'68 912's have a button that you have to press to open the vent window. It's in the center of the lever. If it's covered with a black rubber/plastic, it's been updated to the '68 part.(no lock)
I've seen where people will seal the vent window to prevent potential theft issues. Try moving it by hand to see if it's somehow secured. It should have a bit of play . The tiny pin holds the lever to it's shaft.
Welcome to the 912 world. Having a type Vl back there is a nice upgrade in torque.
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 06-19-2017, 01:01 PM
OK I am a total goober..I didn't realize that I needed to push the button....once I depressed it, the window opened easily...ha ha ha - amazing that I couldn't figure this out. Thanks - still working on the manual window coming off it's track. thanks all
Old 06-19-2017, 06:15 PM
Easy fixes are almost always the best!! Glad you got it figured out; good call Tony!!
Peter
Old 06-20-2017, 04:42 AM
Window pivot breakage is common; the window maybe be loose in its rail... Window pivots are readily available but there are four different types (length and slot orientation); disassembly is required to determine which.
Broken pivot:
Window rail:
Peter
Old 06-20-2017, 04:53 AM
One other thought: check the track mounts in the door. Since it looks as though a lot of work has been done, the track my be loose/improperly installed.
Peter
Old 06-20-2017, 05:02 AM
I took the outer door panel off. There is an inner metal panel that is bolted to the door. Behind that the window seems stable in the rail, but when the window is all the way up the front part of the mechanism feels fine. as I crank it down the front part of the mechanism becomes very wobbly while the rear part of the mechanism feels stable. by the time it is 3/4 way down, the front metal frame can noble almost an inch side to side....i took photos if needed
Old 06-20-2017, 06:16 PM
showing play in window. lower mechanism. this is the end that is super wiggly.
Old 06-20-2017, 07:14 PM
This 'imprint' makes it look as though the window is loose in its rail (or has been repositioned in it).
Does the glass exhibit any 'rocking' as it is lowered? With the glass half way down can either fore/aft upper edge be lifted any amount more than what could be considered normal wear and tear?
If everything seems tight, the inclination of the window with respect to the lift can be adjusted (but it seems something else is amiss):
Old 06-21-2017, 04:16 AM
SO when half way down, yes the fore end of the glass can be raised about 3/4 inch but also can wiggle even more side to side. I also noticed that the glass appears fairly curved especially the front. More than being able to be raised, though, the glass jumps the track to go inside as soon as it is raised an inch or two and by halfway up cannot be put in track unless I lower it almost all the way and guide it manually onto the track. It really wants to bow with the front end inward....
Old 06-21-2017, 06:57 PM
With the window down there is a gap between the glass and the track
Old 06-22-2017, 10:44 AM
Broken pivot:
Window rail:
Peter
Peter,
your window looks much further forward on the rail than mine...is that typical?
Old 06-22-2017, 10:46 AM
Yes; this window came from a MY68 parts car and window is still securely fastened to rail.
Peter
Old 06-22-2017, 11:46 AM
In the picture above with your hand, and finger at edge of glass.... There is a bolt visible from the outside surface adjacent to your hand... this is an adjustment device .... you may be able to loosen it and adjust the window frame to be closer to the glass. this will get rid extra movement.... you may have to play with moving the parts around and possibly use some washers to shim the frame closer to the glass...
Old 06-22-2017, 01:10 PM
COOL! thanks - will try that in the am!
Old 06-22-2017, 09:22 PM
