So who has hooked up a MSD to a 914-6?
It the new happy me!! People have said I am a jerk in the past, but I'm not, I'm just direct and dont sugar coat everything I say . Sorry, I will be happy now, YAY YAY . I think its funny the reaction people have from an expressionless internet post.Anyway i have installed a MSD-6AL in my 914-6 3.0 (83 distributor) how to I hook up the distributor to the box? Do I jump both of the wires from the green wire into the MSD's white wire? Why is a 78-79 SC distributor better than a 80-83? I have heard this from many people but I have heard no explination as of yet?? Remeber this is a happy post! No jerk off replies please, keep the energy positive. No spell checking either, please, this is not a gramar classroom.
VintageExcellence.com |
Grammar, schmucko.
=P ![]() M
I wish I had a dime for every penny I ever had. http://www.914club.com/bbs2/uploads/blog-1136350347.jpg |
canna change law physics
I hooked up an MSD to my Factory 914-6 last year. What fuel system are you running and which distributor?
I need to pull out the wiring diagrams, but I connected the MSD up to the factory CD wiring. Sounds like you have a 6 conversion. Were you using a standard coil or were you using a CD unit from the 911? James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
There are many threads about this on the 911 board - I think you will get more info on this over there (try a search over there, too).
Disclaimer: This is an expressionless response. Do not take any part of this post to contain spell checking, grammar lessons, happy thoughts, insults, tomato throwing, belching, Mike Zois' butt, or references to Dave's weight. |
Geeze James....
What's that "crack" about? James Mike Z's butt??? There are worse....seen "fatjump.jpg" ?
I was trying to give a real answer to confused, and add a little humor that the regulars around here would understand. Nothing bad meant to confused.
This is so funny
. Much better format. I know I will check the 911 board, but I was lazy and started here. I have a 1983 SC engine with a stock distributor, PMO carbs, MSD-6AL with a blaster high vibration coil, magnacore wires, bosch plugs. The distributor has a green wire comming out of it with an outer and inner wire. I know how to hook up the box but does the msd sender wire go to both wires comming out of the distributor. I was just wondering if someone knew off hand, and the distributor question, what is the reason to use a 78-79 distributor? Thanks for any help Redbeard (or should I say Thanks Laddy) "This message was not intended to piss somebody off, this disclamer was not well thought out, but this disclamer does disclame me from any speeling errors"
Administrator
I believe that the 78-79 distributor is preferred because its advance curve better fits a non-CIS 3-liter 911 engine's needs.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
The wire from the Tach does not sound like a standard tach. Hook up the tach signal wire to the tach connection on the MSD. If you are using a Standard style 911 Tach, most likely, this will not work. You will need to send the tach out for work. Do a search on this in the archives, I went through this last summer.
James
