roll pin source
i want to replace the rear shift linkage bushing on my -6 tail shifter. it looks like i need to remove the "lock pin" (roll pin) that holds the selector to the shift rod, numbers 48 & 49 in the exploded view, http://www.pelicanparts.com/914/Parts/Pedals/shift_linkage_tail_big.htm
it looks like it's the same roll pin that's in the pedal cluster rebuilt kit. PP didn't have them and said they are NLA from porsche. any ideas? TIA!! doug waters
doug waters 70 914-6 dougwatersfotos.com http://www.flickr.com/photos/dougwatersfotos/ |
Doug,
Try a FLAPs, I've gotten them there. Unless you need a gin-u-wine P-car part. Paul
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
I would suggest a really good hardware store in your area, if you have one. I'm talking a real hardware store that carries rows of hard to find stuff.
They will have a better quality, bigger selection of stuff. Ideally, you're lloking for a pin that appears to have been "tucked" not one where the spit edges just meet . The tucked type pins are much stronger. You aren't likely to find those at any FLAPS, or even Home Depot, or Lowes. Don
Don Kiepert '73 Big Bore '02 GTI 1.8T Race a Porsche - There's more to life than left turns! |
ein6er, if your search is fruitless, send me a private email w/ address and i'll pick up a couple of the triple rolled type at the place i got mine and i'll throw them in an envelope. replacing this tiny piece made an unbelievable dif in my tail shifter. if you go to a industrial type fasterner store you may have better luck.
kevin |
PP, our host, should have the real McCoy.....the last one I bought was like...$1. It is metric...not english size. Get the correct one.
thanks for the info!!
hey paul .... i'm no CW!! (-: bowlsby, PP said they didn't have them but i didn't ask if they were out of stock or just don't carry them.... hhmmm maybe i should call again. i guess i could try weltmeister too. kevin, thanks for the offer!! if all else fails i'll contact you. thanks again!! doug
