Set engine timing
Hello, need a little help getting the timing set on my 914 1.7 engine. I have the timing gun connected to the number 1 plug wire and I have removed the plastic plug over the crank shaft pulley. I see the blower housing notch but when I run the engine around 3500 rpm and turn on the timing gun I do not see any timing marks at all. The manual tells me there should be a white line, a black line and a red line on the pulley. I need to set the timing at 27 degrees BTDC.
Old 01-09-2022, 09:53 AM
914 Geek
The marks are not on the pulley part of the fan, they are on the back of it right where the notch is. You either need a mirror to see them in the car, or you need to get your head way into the engine bay. Pelican has a Tech Article that... Ugh, the redesign has lost the photos.
Here's an archived version with the photos: https://web.archive.org/web/20160204070419/https://www.pelicanparts.com/techarticles/914_timing/914_timing.htm
If you still don't see the marks, try turning the engine slowly (you can use a wrench on the alternator pulley bolt) so you can look for them more carefully.
--DD
Old 01-09-2022, 01:04 PM
Brian Minson's Avatar
This might help, did a video on typing my 2.0 Type 4 last year.
https://youtu.be/DWEvopraCxQ
Brian
Old 01-18-2022, 09:29 AM
