testinng resistance on temp sensor II
Can anyone give me a simple way to test temp sensor II without ripping the stinker out. The part of the process I'm stuck on is that it is a single wire. Unlike temp sensor I where ther are two points at which to put your probe on II there is not. What to do, anyone, anyone?
Thanks Nate |
Ornery Bastard
Is it possibly grounded through the threads?
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
CHT? Positive on the spade, neg on the neg battery terminal.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/ www.914club.com |
Banned
Re: testinng resistance on temp sensor II
Alfred |
Checking through the harness at the ECU connector, is a great idea because it tests the entire circuit to emulate what the ECU sees. Understand the results though. If there are problems, you may have a harness related issue and TS2 may actaully be good or vice-versa.
914 Geek
It's a pain to pull the ECU out and then slide off the end-cover to unplug the sucker.
Unplug the sensor, put one lead on the connector and the other lead on the cylinder head. It grounds to the head through its threads. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
