testinng resistance on temp sensor II
Can anyone give me a simple way to test temp sensor II without ripping the stinker out. The part of the process I'm stuck on is that it is a single wire. Unlike temp sensor I where ther are two points at which to put your probe on II there is not. What to do, anyone, anyone?
Thanks Nate
Old 06-19-2003, 08:57 PM
Ornery Bastard
Is it possibly grounded through the threads?
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 06-19-2003, 09:03 PM
chrisreale's Avatar
CHT? Positive on the spade, neg on the neg battery terminal.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 06-19-2003, 09:32 PM
Banned
Alfred1's Avatar
Re: testinng resistance on temp sensor II
Thanks Nate
You measure between terminals 11 and 23 of the (disconnected) wiring harness plug to the ECU http://persweb.direct.ca/aschwenk/djettest.pdf .
Alfred
Old 06-19-2003, 09:33 PM
bowlsby's Avatar
Checking through the harness at the ECU connector, is a great idea because it tests the entire circuit to emulate what the ECU sees. Understand the results though. If there are problems, you may have a harness related issue and TS2 may actaully be good or vice-versa.
Old 06-20-2003, 06:27 AM
914 Geek
It's a pain to pull the ECU out and then slide off the end-cover to unplug the sucker.
Unplug the sensor, put one lead on the connector and the other lead on the cylinder head. It grounds to the head through its threads.
--DD
Old 06-20-2003, 08:21 AM
