ddustan's Avatar
Its My Solenoid... Right?
When I turn the key I can hear the relay,and the various items cut out properly (ie the fan, radio, etc). If I jump the solenoid terminals the starter spins put is not engaging the flywheel. I beat on the solenoid (a year or so ago that freed it up...) For now I am resorting to push starting the pumpkin.....
David Dustan
Old 07-01-2003, 10:06 PM
handyher's Avatar
Send a message via AIM to handyher Send a message via Yahoo to handyher
could it be the transmission ground strap????
renee
71 914
65 fstbk mustang
97 "burb"
94 pic um up
Old 07-02-2003, 06:51 AM
914 Geek
Always a very good thing to check!!
--DD
Old 07-02-2003, 08:18 AM
besides the strap get some electrical cleaner and clean the terninals and the spade connecters on the starter itself. wiggle them while connected, if they are sloppy crimp on some new ones. if all else fails drive down to tacoma and you can have one of my spares if you're short on cash.
kevin
kevin
here? not so much i think. high five!!!
Old 07-02-2003, 11:30 AM
Jim Smolka's Avatar
Could be the key switch. Next time it does not start, remove the cover off the T-12 connector (just the cover, not the plug itself) located at the engine compartment relay board. Then, use a jumper wire to touch the large red wire to the large yellow wire. (be sure the parking brake is set and the tranny is in neutral). The starter should turn over, if it does, then it is the switch
Old 07-02-2003, 12:05 PM
ddustan's Avatar
You all gave me a few little projects. I'll give them a try tomorrow and report back! Thanks!
David Dustan
Old 07-02-2003, 08:37 PM
ddustan's Avatar
OK... Better late than never, I guess!
Where will I find the ground strap? I'm looking but not finding....
David Dustan
Old 07-05-2003, 11:50 AM
ddustan's Avatar
Never mind... just found it in the PP tranny parts pics.... The strap is intact using the braille method. Moving on....
David Dustan
Old 07-05-2003, 11:58 AM
914 Geek
Try checking the starter system troubleshooting article available in the 914 Tech Articles section of this very website...
--DD
Old 07-05-2003, 12:32 PM
handyher's Avatar
you might want to take ground strap off and replace it or clean it as it is probably as old as your car and caked full of nasty stuff that will not let it do it's job. at any rate a cleaning is a cheap and quick fix.
renee
71 914
65 fstbk mustang
97 "burb"
94 pic um up
Old 07-05-2003, 01:23 PM
also clean the bottom of the trunk where it attach's well and the stud on the tranny.
kevin
Old 07-06-2003, 07:58 AM
