Best tools to have for your 914 project
So what do ya think are the most frequented tools to use besides wrenches or sockets? Mine......Dremel tool, Flathead screwdriver, and a wirebrush
Old 07-11-2003, 08:36 AM
Mr9146's Avatar
A welder, a cutting torch and a prayer book. Oh, and maybe an Automobile Atlanta catalog.
Old 07-11-2003, 08:40 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
A statue of Joboo as well.
Old 07-11-2003, 10:51 AM
Tonyakavw's Avatar
Send a message via ICQ to Tonyakavw Send a message via AIM to Tonyakavw
A large bank account.
But seriously, I'd say a good selection of vice grips for taking things off that don't want to come off, and for a million other random uses.
-Tony
Tony
70 914 EJ25 - Body by Karmann, Engine by Fuji Heavy Industries
Old 07-11-2003, 10:58 AM
canna change law physics
red-beard's Avatar
13mm socket
But seriously, it will depend on what you're planning to do...
A few suggestions:
An extra 10mm and 11mm wrench, since you need these for the jam nuts.
Visegrips for those things that need to come off and you're gonna replace them anyway.
Probably a 17mm Allen so you can replace the tranny fluid (Check before you buy, as I've seen 3 styles - 17mm allen, 17 mm normal and 13 mm normal).
The special tool for the CV joints if you plan to play there.
A 4mm socket with long extension (Get the 1/4 drive) for adjusting the rear brake venting clearence.
A good manual. Which one depends on how deep you want to go.
Dremel and wire brush are good.
Lots of anti-seize to brush onto the nuts, washes, etc
A good jack, jack stands and drive up ramps.
Penetrating oil for those "Rust free" items.
Patience, a sense of humor and many many colorful swear words. German ones are best!
James
James
Red-beard for President, 2020
Old 07-11-2003, 11:31 AM
ruddyboys's Avatar
a good tool wench and a case of Bud
74 LE "Bumblebee"
03 Jetta Wagon
Old 07-11-2003, 11:41 AM
scg scg is offline
scg's Avatar
Hammer.
BFH (rear hub tool).
6' cheater bar
Really BFH (to hit cheater bar with) -OR- 200#+ Friend to lean on cheater bar...
Goat or Chicken to sacrifice prior to any electical troubleshooting.
Scott
74 914-6 2.7
Old 07-11-2003, 12:05 PM
A huge flat-head screwdriver for removing engine tin screws.
Old 07-11-2003, 12:06 PM
SGB SGB is offline
SGB's Avatar
Pelican Parts Tools... I can never find 'em
Best tool? Pelican BBS. Then beer and bandages. Also cat liter to soak up spilled beer or blood.
Really, for on-board tools, you need a 13 mm socket w/ wrench and swivle extension (everywhere), two 10 mm open end wrenches (clutch adjust), 11 mm wrench (timing adjust), couple sizes phillips screwdrivers, vice-grips, and duct tape. At home you also need a BF flat head scewdriver (valve covers), a BF Hammer (multi-use), pipe to make cheater bar, and a floor jack & jack stands.
Lastly, much $, much patience, high pain tolerance, understanding family, and strong obsessive/compulsive tendancies.
-Scott
My gallery page
Old 07-11-2003, 12:23 PM
auh auh is offline
auh's Avatar
Send a message via AIM to auh
I don't own a 914, but I can imagine that this web board it prob the best tool to have
Adam
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 07-11-2003, 01:42 PM
sleepdoc's Avatar
The one tool besides the regular wrenches and stuff that makes working on these typically corroded cars a joy is a compressor and air tools. Using an air hammer to motivate a stuck axel stub, a tie tod end, or an impact wrench to loosen the axel nuts makes every big job shrink to human porportions. Wow taking out the universal joint bolts, the rusted motor and transmission mount bolts, the brake calliper bolts, the frozen wheel bolts,all that big
stuff that requires superhuman strength and ungodly long prybars and guarantee skinless knuckles, succumb docily and without breakage to the relentless tap tap tap of an air hammer.
You can cut grind chisel, and generally exert your will without getting hurt. And the stuff is just not that expensive.
best Mark
Old 07-11-2003, 02:16 PM
Rouser's Avatar
Send a message via ICQ to Rouser Send a message via AIM to Rouser
When you go out for those (frequent) test drives, make sure you bring , or , and 1 each .
These should ALWAYS be part of your toolbox, regardless of your faith in your work.
Rouser!
Old 07-11-2003, 02:31 PM
scg scg is offline
scg's Avatar
mmmmmmmmmm air tools
On my list of things to get soonest (cheater bars are hard to use in tight places)
Scott
74 914-6 2.7
Old 07-11-2003, 03:47 PM
unclerichy's Avatar
Tool wench to hand them to you.
(and hold your beer)
Rich
'73 1.7
'74 2.0
Old 07-11-2003, 03:56 PM
I am not sure they count as "tools", but Paul Heery, John Eckl and Dan Jacobs.
Old 07-11-2003, 04:45 PM
VARam1500's Avatar
No one has mentioned an ice pick but I'd bet you've all used one on your car at some point!
I'd also contribute my pair of "very-needled" needlenose pliers. Comes in very handy for getting the screws out of those places where you can see 'em but you can't get your fingers to 'em. Also I sharpened the points on them and used them to remove/insert that snap ring in the rear calipers that holds the sombrero in.
--Case...
'75 1.8L L-jet 914
Old 07-11-2003, 07:02 PM
A "deep offset" box wrench sure makes valve adjustments a lot easier on your knuckles. (Won't ramp up the adjacent rocker, and slip of the adjuster nut.)
By the way, does anyone know where I can get a universal joint to replace my elbow. There are a lot of times where things would be easier to reach if only I could bend my arm in the opposite direction.
Howard
1974 914 2.0 "pearl" white
Every so often, I even get to drive it!
Old 07-12-2003, 05:09 AM
Hey Bartender! JoBoo needs a refill!
1972 914/ 1.7 ltr, Saturn (chrome) Yellow, Brown interior
Old 07-12-2003, 10:05 PM
My favorite thing to have around is a buxom, german speaking, blue-eyed blonde frauline....did I mention buxom? They are great for translating German repair manuals, and handing you things you need like wrenches or beer. Hey! Who knows more about Porsches and Beer than the Germans?
Auf Deutsche bitte. Zwei beers meine schotze.
Old 07-12-2003, 10:14 PM
2 floor jacks. you won't believe til you have em. then it's "why didn't i think of this sooner".
kevin
here? not so much i think. high five!!!
Old 07-13-2003, 04:13 PM
