Help! Engine started missing bad & needs to be fixed quick
Help! This is for a 1974 L-Jet 1.8
I was driving to work today just like normal - engine was running perfect. As I pulled into the parking lot, the car started missing (bad). Felt like it was running on two cyl.
I drove at lunch & the car idles fine but starts to mis & cough as I step on the throttle.
My Theories:
Throttle position sensor - car has been jerking on occasion lately.
Petronix - just installed 2 months ago
Head Temp Sensor (it's new too).
I need to fix this quick. I'm going to the mountains tomorrow afternoon (bringing a new date!). If necessary, I will drive another car but I really, really, wanted to take the 914.
I have a spare throttle position sensor & I'm going to switch out tonight - just in case.
I may switch back to points too - just in case
Any Thoughts would be Great.............................Vern
Old 08-08-2003, 03:22 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I'd check for loose wires, cables, vacuum hoses... Sounds like something may have gotten knocked loose..
Old 08-08-2003, 03:34 PM
Contact trigger points perhaps.
Old 08-08-2003, 03:59 PM
914 Geek
The throttle position switch in the 1.8 doesn't do an awful lot--and will almost certainly not make the car buck. There are no FI trigger points. The 1.8's L-jet FI gets its RPM signal from the main ignition points.
I'd look for loose wires and hoses, or ones with poor connections, just as Jared said.
--DD
Old 08-08-2003, 04:04 PM
grind weld build
sean_V8_914's Avatar
double relay plug under the battery tray. clean it and slightly re-crimp the contacts. this thing will make your L-Jet buck intermittently. car will not run if temp II circuit opens. The 4 pack of resistors AKA cigarett pack, for the injectors is in the same location as the double relay. battery acid and acid vapor does a number on these components. My 1.8 had an open in teh cigarett pack that caused #2 injector not to fire intermittently. I hope this solves your problem.
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 08-10-2003, 03:22 PM
