auh auh is offline
auh's Avatar
Send a message via AIM to auh
Next problem
When ever I hit the brake pedal or use my turn signals, I lose all my gauges and my generator light turns on.
When I got home, I checked my fuses and one of them was burnt out.
Unfortunatly I don't know what it goes to.
The fuse box cover has the letter K next to it and a box with 6 vertical lines and one horizantal line.
What is this fuse for and is it the cause of my problem?
Adam
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 08-18-2003, 03:41 PM
canna change law physics
red-beard's Avatar
Ground issue.
James
Red-beard for President, 2020
Old 08-18-2003, 04:11 PM
red-beard's Avatar
Probably in one of the bulbs in the back end of the car, or the wiring is messed up in one of the tail lights.
James
James
Old 08-18-2003, 04:16 PM
red-beard's Avatar
One other thought - It might be a bulb in the rear which has too high a wattage rating. This combined with a cheated fuse could do what you are describing.
James
Old 08-18-2003, 04:18 PM
philinjax's Avatar
Replace the fuse, it should be the 4th from the right side, S9.
philinjax
Old 08-18-2003, 05:11 PM
Conrad W Peden's Avatar
Had same problem. It was one of the wires for the taillights.
After I replaced the bulb holder I was damned if I could get all the wires to fit back in the tail light bucket. Guess I pinched one.
PS. If your losing your speedo too it might be somethin else!?
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 08-18-2003, 05:28 PM
I get the exact same problem every once in a while. Replace the 4th fuse from the right (even if it dosen't look blown). This should solve the problem.
Old 08-19-2003, 02:19 PM
