ws91420's Avatar
Send a message via AIM to ws91420 Send a message via Yahoo to ws91420
Question Shift boot at trans
I am looking for a clamp for the shift boot on the side of the trans. Tweeks ( sorry guys) used to carry them. Any ideas on what might work??? size??? I was thinking maybe a cv boot clamp?? Any suggestions.
76 914 2.0 (critical condition)
73 914 1.7 (new project)
04 Pontiac Aztek (parts hauler)
Old 12-02-2003, 06:56 PM
Rouser's Avatar
Send a message via ICQ to Rouser Send a message via AIM to Rouser
Just buy a clothes dryer hose clamp, the kind you tighten with a screwdriver.
Makes it a whole lot easier to remove.
Rouser!
Old 12-02-2003, 07:27 PM
canna change law physics
red-beard's Avatar
A couple of long tie wraps connected togethe also works.
James
Red-beard for President, 2020
Old 12-02-2003, 07:43 PM
I bought a new one several years ago from Automotion (now Performance), but would now try PP first since they support this board.
Would several large standard hose clamps, linked together to form one long enough, work?
Mike
Old 12-03-2003, 06:18 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
1 or 2 large clamps from local hardware store, might even be stainless, at the right price. i think the factory clamp was not reusable as it was tightened with a band not a screw/worm gear band (if that makes sense!)
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 12-03-2003, 08:18 AM
914 Geek
Yes, that makes sense--but I do think it could be tightened. Just not by me... The tie-wraps are not strong enough, BTDT! You can get them close, but they still won't hold the boot on. Try hose clamps (link a couple of large ones together), or do the tie-wrap thing and then run a couple more tie-wraps around the boot from top to bottom. It's ugly, but it works...
--DD
Old 12-03-2003, 08:32 AM
John Rogers's Avatar
Harbor Freight sells a couple of different sized hose clamp kits that come with the band material and several fittings so you can make clamps of any length you wish. Very handy
Old 12-03-2003, 09:32 AM
red-beard's Avatar
Sorry Dave, but I've been running 2 tie wraps and it does work.
James
Old 12-03-2003, 10:23 AM
914 Geek
Hmm. Didn't work for me. They were loose enough that the boot would slip off the console. When I tried to tighten them, they broke. Perhaps with stronger tie-wraps?
Aaah, whatever. I've got something that works.
--DD
Old 12-03-2003, 04:42 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
How exactly do you GET the boot on, Im having a lot of trouble fitting it over the lip on the firewall, and I dont want to rip the boot.
Old 12-03-2003, 04:47 PM
red-beard's Avatar
My firewall boot just slipped on and I held it inplace with tie-wraps.
I think the dryer hose clamps is the best suggestion so far. I plan to use those now that someone mentioned them.
I have also found that on old CV boot can be used to replace the rubber portion of the firewall boot that is NLA.
James
Old 12-03-2003, 04:50 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Jarrad use Hot Soapy water and a paint brush. Just lather up the water and brush it on, the boot should slip on. Steve
Old 12-03-2003, 05:09 PM
D7N7MASTER's Avatar
Yeah!!! Get creative!! I used Permatex UltraBlue. Once it drys - F the clamp. And UltraBlue remains plyable, easier to deal with when you need to replace the freakin nylon shift bushings & dust & grit proof.
www.pelicanparts.com/gallery/d7n7master
Old 12-03-2003, 05:41 PM
ruddyboys's Avatar
Duct Tape Rules, I got the blue to match my eyes.
74 LE "Bumblebee"
03 Jetta Wagon
Old 12-04-2003, 04:35 AM
Stoddard has them.
Old 12-04-2003, 01:15 PM
ss6 ss6 is offline
ss6's Avatar
My local Home Despot has huge "hose clamps", ie 7"+ diameter in their HVAC isle, that should do the trick, if you're into metal.
I use one "industrial strength" tie-wrap (the things are about 3/8" wide, 2 to 3' long, again from HD) for my tranny linkage cover. The trick is to hand tighten the thing, then grab the loose end with a pair of pliers right where it comes out of the clasp thingy and twist about 1/8 turn, repeat until the clasp doesn't click any more. The pliers head acts as a fulcrum and tightens the tie wrap one click at a time. Great for trussing up "detained" terrorists as well...
John
Yellow '76 914 3.2
YPAF
Old 12-05-2003, 02:36 PM
red-beard's Avatar
That is basically what I did, but I used 3 tie wraps connected together.
James
Old 12-07-2003, 08:21 PM
jkeyzer's Avatar
Same here. Two zip ties I had lying around. Used vice grips to get them really tight. Works fine.
And the original metal clamps are reusable if you are careful.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 12-07-2003, 08:49 PM
The original clamps can be reused a few times until metal fatigue sets in and the band breaks.
The OE metal clamp reminds me of the old style can opening device that used to be used on canned meat like spam and corned beef. There was a key attached to one end of the can that you pried up and snapped off. You then slipped the key over the end of the pre-scored band around the can and by turning the key you wound away the band of metal opening the can. Lots of sharp edges resulted, probably too dangerous in todays litigious market!
Mike
Old 12-08-2003, 05:47 AM
M. Hendrix's Avatar
Nothing tastes better than the food that sticks to the lid.
I cut my tongue a couple times as a kid.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 12-08-2003, 06:20 AM
