Banned
Alfred1's Avatar
Which socket should I use to remove axle nut?
Would the Sears 30mm, 12 point be ok or would this GM 30mm Deep 1/2'' Drive Axle Nut Socket be better. I don't really like 12 point sockets.
Old 12-18-2003, 03:24 PM
grind weld build
sean_V8_914's Avatar
I recomend the 6 tp version and a 5 ft pipe or impact air wrench. I prefer the pipe, seems less brutal. If it is resistant, put a torch to it till it gets smokin hot
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 12-18-2003, 03:52 PM
Banned
Alfred1's Avatar
Five feet? I just bought a 25" breaker bar - won't that do it?
Old 12-18-2003, 04:11 PM
914 Geek
Sometimes. Maybe. If you're built like a tank...
Actually, removing the cotter pin and heating the nut up with a torch might make 25" a long enough lever, but I would have the "cheater" pipe ready just in case. Also, pounding on the back of the socket with a mallet (hit as if you were trying to drive the stub axle out) can help loosen things up sometimes as long as you are applying force at the same time.
--DD
Old 12-18-2003, 04:16 PM
grind weld build
I dont even mess around with all that. the 5 ft pipe makes easy work of VW flywheels, vw bug, bus and 914 axle nuts.; I even use the pipe to change tires (removal only) try is once and you'll give it a name. kinda like a pet
73 Orange, CS #601
Trek 6500+
Sean M!
Old 12-18-2003, 04:25 PM
3/4 in air impact wrenches are a great investment. Even the cheap ones I have used have put out quite a bit of torque.
John
Old 12-18-2003, 05:03 PM
grind weld build
Harbor freight and Sears offer an electric impact for those who lack compressor access
73 Orange, CS #601
Trek 6500+
Sean M!
Old 12-18-2003, 07:45 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
DD is correct ,Use a Cheater bar. Have the Biggest Guy you Know Lean on it, just pushing down not bouncing on it. Then Hit the Breaker Bar at the pivot point where the socket is attached. This should knock it lose.Steve
Old 12-18-2003, 07:58 PM
Banned
Alfred1's Avatar
My brother's a powerlifter/accountant - maybe I'll get him to loosen it up for me.
Old 12-18-2003, 08:02 PM
canna change law physics
red-beard's Avatar
Originally posted by sean_V8_914
try it once and you'll give it a name. kinda like a pet
My was called my ****'n pipe. Cause I'd say "****" everything I pushed on it...
James
Red-beard for President, 2020
Old 12-18-2003, 08:22 PM
Acox914's Avatar
Send a message via AIM to Acox914
i just got my dad a 7.5 amp electric half inch impact wrench. 240 lbs of torque baby!
-Aaron
"60% of the time, it works every time"
Old 12-18-2003, 08:56 PM
240 ft/lbs??? After breaking 2 Snap-on 1/2" wrenches with 4 ft pipes attached to them, no way! A 3/4" drive Ingersall Rand impact with 1000 lbs of torque did the trick. Funny thing is that the drivers side came off without much effort. PO must have hauled some BIIIGG people around.
Keith
74 914 2.0 (sold)
96 328is
Old 12-19-2003, 06:57 PM
boogerboy72's Avatar
Send a message via AIM to boogerboy72
wait, are yall talking aobut the nut that holds the rear axels on? Cause if yuo are, Me and my father could use some help geting it off. Ive read jsut to use a cheater bar and get a big guy to lean on it, but how do we keep the wheel from turning. We're thinking about building a rig for it. Then just get the guy whose gonna paint the car to break it off. Im pretty sure hes big enough, his hand covers 90% of my chest, and well....he right strong.
Musha ring du ma do dum a da
73 1.7 (mine) possible a 2056 from Raby a LONG ways down the road.
74 2.0 (dads)
My lug nuts have more torque than your civic does.
Old 12-20-2003, 05:53 AM
Banned
Put the car on the ground. Steve
Old 12-20-2003, 08:04 AM
i knew that. Thanks man.
74 2.0 (dads)
Old 12-20-2003, 09:31 AM
Jim Smolka's Avatar
Step up to the 3/4" stuff. The good stuff (Snap-on, Mac, Matco) is nice but very $$$. Overseas stuff works OK.
Sears has some 3/4" stuff too.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 12-20-2003, 10:29 AM
mike95125's Avatar
Ok, everybody
Ohm...heat, beat, repeat, heat, beat, repeat...ohm
The 914 mantra
Then cut the beyatch off
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 12-20-2003, 11:49 AM
jcwade's Avatar
Leave the wheel on the ground and you can turn it without any problem.
I must have been lucky, I took off both castle nuts with a 2 ft
breaker bar and a 30mm axle nut socket ($8.99 from Pep boys)
and didn't have any trouble. But I sure was expecting some after
reading these posts.
I hope you're luck is as good.
john
Es könnte schlimmer sein
Everything is funny as long as it is happening to someone else. -Will Rogers
Old 12-20-2003, 07:34 PM
Member w/ Title Problems
Jason Porter's Avatar
I use a 2 ft. breaker bar on my axle nuts. But I can bench press 300 lbs....Come on now, admit it, how many of you would like to be young and stupid again?
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 12-22-2003, 11:50 AM
Also, IMHO, use a 6 point. More solid for the type of torque we're talking about.
Old 12-22-2003, 11:55 AM
