need Throttle body/TPS help
hello all,
my 1974 Djet 2.0 throttle body is shot.. and I think I ruined the electrical part of it also (TPS I believe)...
so what years and models of parts will interchange economically with mine... I'll hit the classifieds to find a used one after I know which specific ones will fit...
tia
brant
Old 03-05-2004, 11:17 AM
914 Geek
Like I said on the 914club board, get one from a 2.0 liter 914. I don't think any of the others mount correctly.
The early 73 TB has a simpler throttle bellcrank and no "supplemental return spring", but is fine to use.
Some/many of the 74+ TBs did not have vacuum advance fittings. You can simply leave the advance hose not plugged in.
If you get a TB with a vacuum advance fitting where you didn't have one earlier, just hook it up to the advance fitting on the distributor. No prob.
I think that the 1.7 and 2.0 TPSes are the same, but the 1.8 ones are very different.
--DD
Old 03-05-2004, 02:10 PM
